Old 01-12-2003, 06:34 AM   #1
Question Contents of holding tank frozen.
The contents of the holding tank on my 350 Classic are frozen so I assume it cannot be dumped. The coach is stored outside in the cold New England climate and I have not been able to find a heated garage to let it sit a few days and thaw. Does anyone have any suggestions on what I should do, if anything??
Dave Emmerich is offline   Reply With Quote
Old 01-12-2003, 06:48 AM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
Lightbulb Idea~
Dave,
You must have some vacation time on the books..
Why not take a trip to FL for a week~?
That would warm your soul and, thaw the tanks..
(just my.02 cents) <grins>
Or, let's assume you're not able to get away..Turn your furance on and, run it for several days or until the tanks thaw out..The hot air from the furance will circulate under your floor and thaw the tanks, etc.
Oh, man..I hope you didn't freeze the water lines too~?
Good luck to you from NH..
ciao
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 01-12-2003, 07:04 AM   #3
LOST , Hawaii
How full are the tanks? If there is only an inch or so, you are probably ok. The hard plastic drain lines are 3" and will crack first. If there is more than that the drain lines or valves might have already broken and once thawed you need to get them drained quickly or deal with leaking sewage. If it is pretty full I would thaw them and find a place to dump before it ruptured the tanks. They are expensive and a lot of work to change. The furnace heats the holding tanks. If you have enough propane they will thaw.
John
74Argosy24MH is offline   Reply With Quote
Old 01-12-2003, 07:18 AM   #4
Thanks for the suggestions. Water lines are not frozen, I just bought the coach in November and had the entire vehicle looked at by a local RV service shop. They told me that the tank is about 50% full and when I open the drain valve it is about half full of frozen water. The seller claims it is grey water. If I pour non toxic antifreeze down the toilet will that break it up??
Old 01-12-2003, 07:34 AM   #5
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I do not belive the anitfreeze will break it up. It is designed to prevent freezing not reverse it. You may want to try some rock salt mixed in water dumped down the drains. One big concern I would have is the water in the traps. There is room for expansion there but if they are frozen as well it will be difficult to get any type of un-freezing solution to the tanks until you melt them.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 01-12-2003, 08:14 AM   #6
71tradewind's Avatar
Dave "Grey" water is not connected to your toilet , it is the water from you sinks and shower , The rock salt approach may not be all bad with the exception that mineral salt stops working somewhere around 17 degrees F. Good luck !
71tradewind is offline   Reply With Quote
Old 01-12-2003, 08:35 AM   #7
Just a member
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
I was thinking the rock salt with a bit of running the heat should allow the frozen fluids to at least turn to a slush that could be dumped with some additional water.
The rock salt may quit working as a melting agent at 17 degrees, but I belive it wall act as a anitifreeze to at the very least stop the hard freeze that will break things. Also I would caution against using a chemical de-icer pellet to do this as you may damage the tanks or valves, and that is what you are trying to avoid.
Brett G
Old 01-12-2003, 09:20 AM   #8
Retired Moderator
john hd's Avatar
1992 29' Excella
madison , Wisconsin
Images: 40
how about this instead?
make a temporary skirt for the trailer out of tarps then beg borrow or rent the biggest salamander heater you can get your hands on.
heat the under side of the trailer trapping in the warm air with the tarps. every thing should thaw in a matter of hours.
if it is in fact grey water, you could just let it run on the ground.
directing the hot air blast at the valves might work the best as i suspect this is where there would be the least amount of insulation around the tanks.
john
Old 01-12-2003, 10:18 AM   #9
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
I vote for the trip to Florida!
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 01-12-2003, 03:24 PM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
JOHN had the same idea I was going to suggest- a heater in a "tent" of tarp to thaw, then drain, and then add rv antifreeze to the tank when near empty.
On a related subject, I drained my tank ( so I thought) by letting the water run into the grey tank until it seemed empty. Then I took the plug out of my water heater and used a shop wet-dry vac to suck out the water remaining in it. I had the valve open from the tank, and ended up vacuuming out almost 10 gallons! Freaked me out as I thought the tank was empty, and my info panel said it was empty also.
I added 2 gallons of antifreeze to the nearempty tank, and shut the bypass on the hot water heater. Phew!
Old 01-12-2003, 07:31 PM   #11
Vagabond
TheBigRedTruck's Avatar
1973 31' Sovereign
Fort Meade Md. RV park slot 8!! , Motorsports Photographer
Images: 36
Send a message via AIM to TheBigRedTruck
Talking
Use the furnace!!!!!!!!
Never has so few. Done so much, With so little, That now we can do anything, With absolutly NOTHING!!!! AIR# 300
TheBigRedTruck is offline   Reply With Quote
That pesky grey water that bypases the holding tank Van All Argosy Trailers 15 08-13-2004 07:52 AM
Pulled the plug out of the Holding Tank? ssolid Fresh Water Systems 0 03-24-2004 11:13 AM
Holding tank warming TomW Repairing/Replacing Floor &/or Frame 5 01-07-2004 11:03 AM
Holding tank plumbing question yukionna 1997 - 2004 Bambi 15 09-10-2003 08:00 PM
Replacing Metal Box for holding tank Mike Waste Systems, Tanks & Totes 11 10-26-2002 03:40 AM
