Originally Posted by curmugeon
I would like to have a compass to augment the navigation system on my Airstream Interstate. As far as I can tell, there is no compass mode in the Garmin navigation package installed on the Interstate.
You
can select to have the GPS display direction in terms of compass points but not in terms of degrees. Or at least I can on my DNX7180. But it took some experimenting to accomplish it, because my DNX7180 manual didn't cover the Garmin GPS program, only the other functions.
I forget exactly how I did it, but if you touch the lower-right corner display, you should be able to select direction, mph, elevation, or distance to destination. Maybe one or two others. After one particular update to the firmware, I could display up to four stacked data windows instead of just one in the lower right. I liked that so I've left it that way for the last couple of years.
