Old 02-08-2004, 09:25 PM   #29
Have just read the many post to this thread and thought I would offer my two-cents. I'm a mechanic and have r&r'd several of these GM454's in motorhomes. As mentioned, best way is use of the forklift. You may have to remove one fork depending on the lift, usually not much additional work. It comes out the front after removing all of the 'up front stuff'. Do not take the oil pan off. If you have the funds, go ahead and upgrade the engine-there are many after-market choices here (without knowing your desired driving habits, total expected vehicle weight, towing a 'toad', etc) I will not offer specifics other than to say you should install a new distributor/coil/wires and complete exhaust system at the very least.(Look at Banks.com + others) The GM454 is a very good engine and in your motorhome it does not matter if you have 2bolt or 4bolt main bearing caps-its plenty strong as is. Pick a very good rebuild shop near you with a very, very good reputation and tell them to rebuilt to GM OEM Specs. Ask for a slight overbore only if needed; you'll get longer block life with room for additional overhaul or one cylinder repair if future problems develop. Replace the fuel pump and starter with good quality units-not the junk from local 'pop-parts' and have the carb overhauled at an approved shop. When you re-install, pay attention to air intake curves and turns-the more restriction, the less power. Add a good quality high-flowing air filter also. Don't forget the transmission, now is the time to replace those clutch packs-its not that expensive, and your 'new' engine will feed more power into those old, used clutch faces-so now is the time. Don't forget to boil-out the radiator, new hoses and such - but you knew that, right? Happy motoring
tcal is offline   Reply With Quote
Old 02-10-2004, 06:49 PM   #30
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
"van engine puller"
that is the buzz word for the engine puller needed to pull the motor out the front of the classic motor home.
i stopped at my favorite rental tool store today and ask if they had a puller for pulling motors out of vans and they said yes. but it is the same puller except if i want the puller for a van it gets a different boom and set up. would have to call a day ahead of time so they could reconfigure the standard puller.
they showed me a pile of steel tubing and hydrolic cylinders . the biggest thing was the boom is a foot shorter than the standard puller. and the boom would go in low and jack up. that will solve the problem created by the cherry picker style puller. cost $20 a day fork lift $125 a day.
haven't decided which option i will do on the motor. least money is local rebuild. company has been in business for 50 years. or a groom engine form Nashville, available thru napa. haven't seen a spec sheet for that motor got a price. could also look for a jasper company engine.
in any case we going to start this process after the trip to Florida. hopefully it wont leave me sitting on the road.
AL
2007 chevrolet 2500 duramax 6.6
allison 6 speed
2004 classic 28 WB , Pro Pride P-3 hitch
centramatics wheel ballancers 300-556
wb13798 is offline   Reply With Quote
Old 02-10-2004, 07:03 PM   #31
LOST , Hawaii
The engine on the motor home is quite a bit further back than a van, make sure if it is a foot shorter it will reach.
John
74Argosy24MH is offline   Reply With Quote
Old 02-10-2004, 07:11 PM   #32
wb13798's Avatar
2004 28' Classic
didn't get that one right the support boom is shorter not the lift boom.
some one posted on groom motors in Nashville. i cant find the post wanted to ask him a question.. if you read this pm me
al
AL
allison 6 speed
Old 02-11-2004, 02:58 PM   #33
wb13798's Avatar
2004 28' Classic
just got specs for groom motors products. two bolt mains new pistons not more than 40 thousands over,normal production run is 20 over. RV cam, crank corrected to no more than 2 thousands under size cut/polish. around $1800 plus freight and taxes. totals up to just over $2000. over night delivery.provided a motor is available
local build would be about $1800 plus and take a week. for a company that has been in business 50 years. i cant find a proud owner of a motor they built. did find a unhappy customer who had a set of heads they didn't get right first time.
probably going to go with the groom motor just for the convenience and timing. i live in one of those areas that will call the city and complain. if i have the rig tore down to long. probably will have to say hello to an inspector any way but not much he can say if the motor is back in the rig.
AL
allison 6 speed
Old 02-14-2004, 09:33 PM   #34
Lightbulb isuzu engine removal
I removed the Isuzu engine from our 82 Classic out the bottom and put the cummins back in the same way. Remove the entertainment center and the front seats. Remove the transmission first and build a framework inside the vehicle to hold the chain hoist and lower the engine out the bottom. I cant imagine trying to pry that thing thru the front. The engine was let down rear end first and lowered to the ground and then tipped on its side and drug out on a pallet. The front wheels need to be about 2 feet off the ground to give you the room. Just another way of doing the job.
joe
joepospisil is offline   Reply With Quote
