Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Prev Previous Post   Next Post Next
Old 11-01-2003, 11:19 PM   #1
Jim Tyrney's Avatar
Profile:
Question Chassis/House Battery Charging 4 Motorhomes
When the 86 345 is plugged in to shore power, does the Univolt only charge the coach batteries and not the start battery? I think that is the way it works thru reading threads, manuals, voltmeter, etc, Is it possible to charge start battery with Univolt if it is not set up to do this? When on shore power, I checked isolator and 13.6 VDC @ top connection (coach batteries), 0 VDC @ center connection and 12.2 VDC @ bottom connection (start battery). I believe this should be correct. Thanks for any replies/help. Jim
"Property doesn't have rights, people have rights to property"
Jim Tyrney is offline   Reply With Quote
Battery Location uwe 1970-79 Tradewind 22 09-04-2003 08:44 PM
Charging time for battery while towing John Electrical - Systems, Generators, Batteries & Solar 2 12-23-2002 04:14 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 03:58 PM
Solar battery charging Charles Q Treichel Generators & Solar Power 23 10-17-2002 11:22 AM
Battery Dead/Power jack question jcanavera Jacks, Stabilizers, Lifting and Leveling 34 08-16-2002 02:51 PM
