Old 06-06-2007, 06:58 AM   #1
1968 22' Safari
1982 28' Airstream 280
Gloucester , Massachusetts
Cargo Weatherstrip?
Hello, I picked up a 1982 Turbo Diesel 280 which had been in Florida most of the time. A lot of the window seals are dried up and brittle. I see replacements out there, Expensive (overpriced) but available.
I ended up driving through the mountains in Va and Pa during a NorEaster (side note:heavy Rain, bad wiper linkage, don't mix) in April, I had some items stored in the cargo bays along the way, the cargo bays got very wet. I had a basin in the front one drivers side, it collected a few inches of water in it.
There appears to be no seal around the door/hatch, is this correct?
Do these storage areas all get wet?
I expect some water to mAke it through the bottom hinge But to make it into a 6" deep basin?
I did a quick search but didn't see any posts on this, I hope I'm not asking repeat questions.
Regards, Art
ajheinonen is offline   Reply With Quote
Old 06-06-2007, 07:17 AM   #2
yukionna's Avatar
Massachusetts
Images: 18
Send a message via Yahoo to yukionna
Welcome to the forums!
There actually should be a gasket around the inside edge of the exterior doors. I have found that Vintage Trailer Supply - Vintage travel trailer parts and supplies! has a good selection reasonably priced.
WBCCI Region One
Attitude is the only difference between ordeal and adventure
yukionna is offline   Reply With Quote
Old 06-06-2007, 07:55 AM   #3
lewster's Avatar
Naples, FL , Hood River, OR
Hi Art and Melcome!
If you don't find what you need at VTS, you can check here: McMaster-Carr They have a very nice selection or rubber trims and mouldings available.
Old 06-06-2007, 11:29 AM   #4
Regards, Art
Your entrance door and storage compartments all use the same triangular shaped gasket.
Our part number is 45308.
The gasket must be install with "super weatherstrip adhesive."
Cargo Carrying Capacity (CCC) of 23' Safari SE LS OrangeKid 2007 Safari SE 45 04-05-2010 09:26 PM
Window Weatherstrip Replacement pittsf Windows & Screens 7 01-16-2010 06:09 AM
thule cargo carriers pfandler Sprinter and B-van Forum 1 09-26-2007 11:03 AM
Downgraded Cargo Capacity SilverCabin 2007 Safari SE 6 06-12-2007 08:16 AM
Suburban Cargo Liner EvelynDickinson Tow Vehicles 0 10-26-2005 10:08 AM
