Old 02-15-2003, 06:42 PM   #1
Tikihut's Avatar
1977 Argosy Minuet 6.0 Metre
schaumburg , confusion
Send a message via AIM to Tikihut
can't keep pilot lit
I have just bought a 1977 Argosy 6 meter. I am trying to lite the furnace with no luck. I can get the pilot to lite but it won't stay lit. I have Suburban Dyna-Trai. The blower works fine. I just can't seem to keep it lit. It will lie when I hold down the rest button but after I let go of it. It stay lite for 20 or seconds and then it goes out. can someone give me an idea on what to try next.
Thanks everyone for you help.
Chris
Tikihut is offline   Reply With Quote
Old 02-15-2003, 07:07 PM   #2
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Greetings Chris!
I am not particularly adept at such problems, but there are three possible causes that I am aware of. The first being an obstruction in the exterior furnace exhause vent - - mud daubers, wasps and spiders seem to love to build their nests in this device causing all types of trouble when the furnace is needed. The second possibility is a problem with rust out in the heat exchanger allowing wind to blow the pilot out - - this is a potentially deadly problem as it means there is a carbon monoxide leak. The last problem that might cause such problems is either a thermocouple or sail switch that has failed or is failing. This is an area that I always turn over to a trusted RV LP Gas technician as it is a life-safety issue.
Good luck locating the problem.
Kevin
Kevin D. Allen
AIR #827
Old 02-15-2003, 07:07 PM   #3
evan's Avatar
Was this Argosy sitting for a long time or did you recently refill the gas? Did you make sure the system was purged of air before trying to light? Run your stove burners to purge the system, if they behave erratically or have lots of yellow flame you have air in the system that needs to be pushed out.
evan is offline   Reply With Quote
Old 02-15-2003, 08:36 PM   #4
Tikihut's Avatar
Yes I t has been sitting for a while. I don't think anyone used for at least 4 or more years.
pilot light on water heater kthomson Water Heaters, Filters & Pumps 2 12-30-2003 08:38 PM
Magic Chef Oven pilot sammamishsafari Stoves, Ovens & Microwaves 2 08-22-2003 08:17 PM
Water heater pilot issues? Marko69AS Water Heaters, Filters & Pumps 8 07-14-2003 09:46 AM
Pilot light adjustment thenewkid64 Water Heaters, Filters & Pumps 9 02-25-2003 04:04 AM
Ref pilot Dbraw Refrigerators 2 08-27-2002 04:43 PM
