Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 04-04-2006, 08:45 PM   #1
Snadi
Snadi's Avatar
Profile:  St. Matthews , South Carolina
Can I pull a 1980 Ford Courier Pickup???
Hi,
I have searched the forums over and am more confused about the toad issue than I was before I started so I figured the best bet was just to ask the question, so....
Can I pull a 1980 Ford Courier pickup truck behind my 1982 Turbo Diesel 280 Motorhome on four wheels??? The little truck is 2wd, manual, and the title says it weighs 2600 lbs.
Any help would be greatly appreciated. Thanks.
Sandi
Sandi Marshall
1982 Turbo Diesel 280 Motorhome!
WBCCI # 9316
Member SC Coastal Unit 150 and Friend of Chuck
Snadi is offline   Reply With Quote
Old 04-08-2006, 09:03 AM   #2
guy99
guy99's Avatar
Profile:  Dunsmuir , California
Images: 16
The rated tow weight for your MH is 2000 pounds. But many of us tow vehicles in the 2200-2500 range, some quite a bit more.
The Courier should be flat towable.
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 04-17-2006, 09:06 PM   #3
Whipsas270
Whipsas270's Avatar
Profile:  Benbrook , Texas
Go for it!!!
I towed a 1984 Ford Ranger from Tampa to Ft Worth to Deadwood, SD back to tampa with absalutely NO problems . I did not use a Brake Buddy or any other system on my toad and had to make a few extreme stops and had no problem with control. Now , this was just MY experience with My 1984 Excella 270
Ps I drove semi's long haul for over 20 years and have a habit of leaving room tween me and the guy up front of me.
Whips excella 270
carrying a
1995 Honda Shadow 1100 ACE
Whipsas270 is offline   Reply With Quote
Old 04-19-2006, 02:04 PM   #4
Chaplain Kent
Chaplain Kent's Avatar
Profile:  Wauwatosa , Wisconsin
The diesel will give you more torque and better towing ability than a gas engine. You should be O.K.
Chaplain Kent
1982 280 Turbo Diesel Motor Home (Chummy)
http://www.fuzzytravel.com/grandakent/
Chaplain Kent is offline   Reply With Quote
1989 370 Ford 460 Overheating 1985air345 Mechanics Corner - Engines, Transmission & More... 14 07-05-2004 03:46 PM
Ford Windstar Gordon Watt Tow Vehicles 61 08-23-2002 08:33 AM
1980 Airstream Land Yacht - Should we buy? cbird01 Airstream Motorhome Forums 0 08-03-2002 09:06 AM
Towing With a 1974 Ford F100 melprice Tow Vehicles 6 07-08-2002 10:28 AM
Ford Diesel RV Puller 3 axle FrankR Tow Vehicles 0 05-03-2002 06:47 PM
