Old 09-17-2009, 12:50 PM   #1
2000 31' Land Yacht
Huron , Ohio
Broken rear shock, bent mount
I've got a 2000 30' Land Yacht MH on the Workhorse P30 with 55K on it. Over the weekend I drove it from Jamestown to Corning across the NY Southern Tier Expressway (I86). The road was in horrible shape, and I broke the right rear shock and bent the shock mount on the axle pretty badly. Does anyone know if the shock mount can be repaired? I'm also wondering if I should replace the leaf springs when I get the rear shocks done because of the age of the unit.
I look forward to your input!
effischer is offline   Reply With Quote
Old 09-17-2009, 01:20 PM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
I would think a good welding shop should be able to repair or fabricate a new mount for you. No need to replace the axel. 9 years old with 55K miles isn't very old. If the springs still look good, and are holding the weight ok, you should be fine. Lot's of welding shops can do an inspection of them for you and eliminate any concerns you might have.
good luck!
Chris
Old 09-27-2009, 09:23 AM   #3
2000 31' Land Yacht
Huron , Ohio
Fixed, springs good
Hi Chris!
The folks at Northern Ohio Truck Center in Norwalk looked the suspension over and determined the springs were fine. They had a very tough time getting the shock mount fixed because it was really mangled, but did manage it. I now have new Monroe heavy-duty shocks at all four corners and couldn't be more pleased. A great shop, excellent work and a fair price. Thanks for your input and if anyone needs chassis work in north-central Ohio, clue them into N. OH Truck.
E. Fischer
Broken Shock Bracket on Lower Control Arm Auretrvr Mechanics Corner - Engines, Transmission & More... 4 08-15-2009 06:15 AM
Rats, broken shock mount dbj216 Shocks 7 07-04-2009 05:01 AM
3 out of 4 Broken Shock Mounts? Lookinghard Shocks 8 04-14-2006 09:08 PM
Broken rear upper shock mount Robfike Mechanics Corner - Engines, Transmission & More... 7 02-27-2006 08:06 PM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 06:34 PM
