Old 08-25-2018, 06:07 PM   #1
1987 32.5' Airstream 325
ETOBICOKE , Ontario
Brake Master Cylinder
Hello,
I need to change/replace my brakes in my 1987 Airstream 325, p30 chassis.
If anyone out there knows the part number I would appreciate your help.
Cheers,
Peter
4airsteam is offline   Reply With Quote
Old 08-25-2018, 07:08 PM   #2
Waipio Rim's Avatar
1984 31' Airstream310
Honokaa , Hawaii
I donít know the part number, but when the MC on our Ď84 started leaking in Maine I stopped at the first NAPA store that I saw and they had one on the shelf. I just asked for a MC for an Ď83 P30 with four wheel disk brakes. The guy at the counter said that it fits a lot of other applications.
Waipio Rim is offline   Reply With Quote
Old 08-25-2018, 09:41 PM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
What Waipio Rim states is true, any Carquest, NAPA or any auto parts store in your area will be able to get brake parts for a 1987 P30 chassis motorhome.
I live less than an hour north of you, it would be great to meet up sometime. PM me with contact info if you wish.
Cheers
Sidekick Tony
ďItís a recession when your neighbor loses his job; itís a depression when you lose your own.Ē "Harry S Truman"
Old 08-26-2018, 03:34 PM   #4
ETOBICOKE , Ontario
Looking forward speaking to you
Peter
Old 08-26-2018, 03:38 PM   #5
Dazed and Confused
Isuzusweet's Avatar
Peter
Thanks for the contact info but you should have Private messaged me that. If you can't edit out the post with your phone number I suggest you ask a moderator to delete it.
I will PM you my number and e-mail.
Cheers
Tony
Old 08-28-2018, 12:16 PM   #6
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
I already copied Peterís number, and I have yours as well, will add them to the list, Regards, Bob
bobmiller1 is offline   Reply With Quote
Old 08-28-2018, 01:24 PM   #7
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
As Waipo Rim and Tony say, this is standard stuff, except for classics with 16Ē wheels which have a different brake/RPO set ups. I think itís a JP9 vs JP8. This can all be extracted from your VIN code from any good parts shop.
Boom Sounds is offline   Reply With Quote
Old 08-28-2018, 01:26 PM   #8
For parts replacement, VIN code is great but the stock part casting number is best identifier.
Master Brake Cylinder in New 2017 AI wildwilly. Sprinter and B-van Forum 6 10-05-2016 12:06 PM
Newbie asks "where's the brake master cylinder?" ducatist2 Land Yacht/Legacy Motorhomes 2 03-22-2011 02:56 PM
Brake master cylinder install Robfike Mechanics Corner - Engines, Transmission & More... 1 01-08-2006 08:37 PM
"Stuff" on Master Cylinder swebster Mechanics Corner - Engines, Transmission & More... 24 09-19-2005 06:25 PM
Master Cylinder Replacement will Airstream Motorhome Forums 3 08-16-2003 06:35 PM
