Join Airstream Forums Today
Old 10-19-2003, 09:36 AM   #29
87MH's Avatar
1978 31' Sovereign
1987 34.5' Airstream 345
Katy , West Planet Houston, Texas
Images: 280
.....also installed the wheel balancers that camping world sells ...
Al:
Could you explain how and where the balancers mount, and how they work?
Dennis
WBCCI # 1113
AirForums #1737
Trailer '78 31' Sovereign Photos:'78 Sovereign Rebuild
Motorhome '87 Classic Motorhome Saga
Old 06-04-2004, 07:49 AM   #30
JanP's Avatar
Wink Shock absorber mounting
The top mounting bolt for the rear shocks on P30 chassis older than 1989 need to be reinforced by a weld bead around the bolt to the mounting bracket. If you buy new Bilsteins you will get this notice in the box. Take-offs offered on e'bay probably wont tell you this. So be advised!!!!
Ernie and Jan
JanP is offline   Reply With Quote
Old 06-08-2004, 10:34 AM   #31
AIRFORUMS # 005
ALANSD's Avatar
1966 26' Overlander
North , Georgia
Send a message via Yahoo to ALANSD
thanks for that ---- most of us who got shocks off ebay bought the fronts. I haven't seen any rears for sale there...although there might have been a set or two I missed.
The front shocks and steering damper on mine made a nice difference in handling.
1966 Overlander Twin w/bunk 2000 Ford Excursion LTD V10
Please visit our blog:
OUR AIRSTREAM PASSION! BLOG
Old 08-04-2005, 08:38 AM   #32
Nick Danger's Avatar
1989 37' Airstream 370
Beverly Hills , Florida
Thumbs up shock replacement 370 LE
I'm trying to find out the manufacturer of the front and rear shock absorbers on my 1989 370 LE. It's on a Gillig chassis with a Ford motor/transmission. I want to replace them but I need a model number to cross reference.
I emailed Aistream and they told me to call Ford at an 800 number. They were more lost than Airstream.
Any 370 LE owners out there that can help?
Nick Danger, Third Eye
Nick Danger is offline   Reply With Quote
Old 05-11-2010, 05:57 PM   #33
DaveFL's Avatar
2000 31' Land Yacht
2000 Land Yacht 30(31') , Inverness, between the Withlachochee River and the Gulf of Mexico, Fl
Shock absorber top mount loose
Originally Posted by swebster View Post
Dennis,
Crawled under there last night to take a better look. Its broken at the top mount (starboard side). The mount itself is rivited to the frame and is fine. Looks like the mounting bolt broke off. The left shock has the same aged "patina" is the right so I'm sure this is worthless too.
Spotted Bilstein shocks on ebay at a good price so thought I would check my old ones, picked on passenger side front, pulled the bolt from the bottom, pushed and pulled and shock has tension, BUT the top mount was loose. took an adjustable wrench on the shaft and a 15/16 socket with extension solved that problem and discovered the bottom bolt wouldn't go back in hole, had to make a point on the bolt to help it find the hole. Sure glad to be doing it in the backyard rather than on the road at a truck stop. Price for repair 0.
X-Ref on shocks? RonJudi Mechanics Corner - Engines, Transmission & More... 4 03-18-2004 07:02 AM
Save yourself from a bidding war on Ebay thenewkid64 Buyer Guidelines 5 01-09-2004 01:40 PM
Hello from new Forumee - and a question about front shocks on my 1989 345LE williamhenshall Mechanics Corner - Engines, Transmission & More... 12 04-14-2002 10:13 AM
