Old 08-09-2003, 08:43 PM   #1
1978 25' Tradewind
Roseland , Florida
battery isolator
Hi,
I was told I need to replace my battery isolator. I am clueless as to what to get. The one in there gives me no indication as to what power it is and looking in the catalogs is no help. Any of you experts out there know what direction to point me in?? BTW my coach is an '84 345.
Thanks!
Eric
kooblekidz is offline   Reply With Quote
Old 08-10-2003, 05:39 AM   #2
uncleneal's Avatar
My '85/86 345 has a Cole Hersee Co. Model 48120 Isolator. Max Amps 140, 12-36 Volt, Negative Ground. My '82/83 310 had the same isolator, so yours should be the same.
Neal
uncleneal is offline   Reply With Quote
Old 08-10-2003, 07:49 AM   #3
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
at the auto parts store they usually have 2, the smaller square one and the bigger rectangular one. The one you need would depend on your alternator output (amps).
You couldn't go wrong with the bigger one.
1991 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 08-10-2003, 02:28 PM   #4
71tradewind's Avatar
Eric , its hard to believe your isolator went bad ,but if it did infact go bad I would recommend using Sure Power Industries battery isolators I have used over 100 of them over the past 18 years at my place of employment and have never had a failure of the isolator, we have seen corrioded connections cuasing them not to work but never an outright failure of the diodes themselves. Before you replace it I would try cleaning all the connections . And as Peter stated it can never hurt to go bigger ,if you do end up replacing it . Here is the url to Sure powers site http://www.surepower.com/Products/batiso.asp Tom
71tradewind is offline   Reply With Quote
Old 08-10-2003, 02:52 PM   #5
Airstream Driver
1997 30' Excella
Images: 51
Originally posted by 71tradewind
.... and have never had a failure of the isolator,....
There is one sure way to blow an isolator:
Reversing battery cables on the coach batteries.
But who would be so stupid to do that??
Now I will go and stand in the corner.
AIR #13
Old 08-28-2003, 06:04 AM   #6
battery isolator
Hi Eric
I just a problem with my battery isolator.I had a neg 12 volts system. I replace the unit with a positive supply and installed a breaker panel to replace the od fuse panel. There is site call batterystuff.com Check that site and look at the battery tutorial very interesting article I bought the 12v/75a model for 389.00 and work beautiful. the life of your battey depend on the quality of battery isilator. Good luck
Andre Baillargeon is offline   Reply With Quote
vintage airstream battery wildcat455 Electrical - Systems, Generators, Batteries & Solar 4 07-02-2003 12:50 PM
Battery Exploded wayner1239 Electrical - Systems, Generators, Batteries & Solar 15 05-11-2003 08:43 AM
Battery Isolator thenewkid64 General Motorhome Topics 20 01-12-2003 09:00 PM
Battery Isolator shelocta Airstream Motorhome Forums 1 10-29-2002 10:32 PM
igniton switch and the mystery of the dead battery Curtis-79MH Airstream Motorhome Forums 3 10-25-2002 02:58 PM
