Old 08-12-2016, 09:24 AM   #1
1985 32.5' Airstream 325
Calgary , Alberta
Bathroom fixture removal
I have run into a problem removing the original bathroom accessories fixtures. Anyone have any experience removing? I cant seem to find a way to unhook from wall. Are they two sided taped or glued to wall?
jimbro is offline   Reply With Quote
Old 08-12-2016, 10:12 AM   #2
Al Boondy's Avatar
1973 31' Excella 500
Vicksburg , Mississippi
Look at the bottom of the bracket on the wall there should be a small set screw
Al Boondy is offline   Reply With Quote
Old 08-12-2016, 08:28 PM   #3
Calgary , Alberta
no set screws are visible. Thus the problem
Old 08-12-2016, 08:33 PM   #4
Calgary , Alberta
no set screw is visible.
Old 08-12-2016, 08:48 PM   #5
1979 23' Safari
Wayland , New York
From looking at them I bet the shiny brass parts slide into the bracket after fastening to the wall. See if you can gently pry one away from the wall.
Old 08-12-2016, 09:32 PM   #6
Calgary , Alberta
HiJoeSilver
I tried to pry the Brass of then turned my efforts to the black insert. The Black insert pulls out of the brass piece and the screws are then accessible.
Old 08-12-2016, 09:35 PM   #7
Calgary , Alberta
Pictures of efforts
ID:	268917   Click image for larger version
Old 08-12-2016, 09:49 PM   #8
1979 23' Safari
Wayland , New York
Interesting design.
Bathroom light fixture Jim Flower General Repair Forum 3 08-12-2016 10:21 AM
Light Fixture Removal jdalrymple Lights - Interior & Exterior 3 04-09-2012 06:25 PM
replacing 12v fixture with LED fixture funkill Lights - Interior & Exterior 2 08-26-2009 10:20 AM
Sink Fixture Removal mello mike Plumbing - Systems & Fixtures 1 06-13-2009 12:03 PM
