Old 06-24-2007, 06:02 PM   #1
1992 30' Land Yacht
Bakersfield , California
Backup Camera System
Backup camera system on my 1992 Land Yacht MH doesnt work. Its a Sony system. The monitor has power, screen lights up but no picture. Does anyone have suggestions where to start? Should I try to have my B/W system repaired or replace it with a color system? Is the installed wiring ok for a color system? What about a new wireless system.
CarlGeo
CarlGeo is offline   Reply With Quote
Old 08-22-2007, 10:15 AM   #2
museumdude's Avatar
2005 30' Land Yacht 30 SL
Van Nuys , California
CarlGeo
Is the camera powered? Can you plug a video camera in or anything that can transmit a video signal over coaxial cable instead of the backup camera, and pess play and see if you have a picture?
museumdude is offline   Reply With Quote
Old 08-31-2007, 12:00 PM   #3
livexl's Avatar
1992 35' Airstream 350
Huntington Beach , California
I just replaced mine on my 350 LE ... I have the info at home but I won't be back until next week ... I'll send it to you then. Please remind me.
dan@beachcombers.com
livexl is offline   Reply With Quote
Old 09-03-2007, 01:24 PM   #4
livexl's Avatar
Camera and Cable Source ... http://rearviewsystems.com/
I plugged one end of the cable into the camera and cut the other end to expose the wires for splicing to the motor home cable later. Mine was hard wired to the camera. I've attached the diagram for the new camera.
The existing wires in the Airstream are:
RED = POWER
BLACK = GROUND
WHITE = AUDIO
CLEAR = VIDEO
The bracket is smaller so new holes need to be drilled and the old ones plugged.
Good Luck, Dan
Homemade backup camera 83Excella Airstream Trailer Forums 28 08-17-2005 01:31 PM
GPS system evaluation paul dahl On The Road... 3 10-29-2002 06:50 AM
Flowmaster RV exhaust system rdm Airstream Motorhome Forums 2 07-09-2002 04:35 PM
Water filter system 53flyingcloud Our Community 2 07-05-2002 05:43 PM
Electrical System Question ViewRVs Mechanics Corner - Engines, Transmission & More... 2 03-16-2002 08:39 PM
