Old 08-05-2018, 04:05 PM   #1
1994 19' "B" Van Airstream 190
hillsboro , Texas
B Van proble
I have a 1994 Airstream B-Van. My question is this:
My tires are going are in good condition (Michelen) but i frequently have flat tires - mostly the rear tires.......AND it's usually not because of a bad tire, BUT BECAUSE of the valve stems going bad.................so what is the problem..........I also have Pressure Pro TMS to alert me of a tire going flat.......I have my tires et at the proper amount of air ............60 psi front and 80 psi back tires.
Could this be a weight issue? I cannot figure out why this is happening....
Thank you for any possible answers...........Roger
midwestmn is offline   Reply With Quote
Old 08-05-2018, 06:14 PM   #2
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Most likely it's caused by having TPMS sensors on rubber valve stems. The extra weight of the sensor on the end of the stem causes the valve stem to wobble and leak.
Replace your valve stems with all-metal ones and the problem should go away.
Cats and ultraleather Airstream upholstery don't mix!
Old 08-06-2018, 08:32 AM   #3
hillsboro , Texas
I forgot to say that I have had the rubber stems replaced with steel, but same problem.......I'm thinking that it's either a weight issue of the van in the back OR
the rear tires are exceeding the psi of 80 rolling down the highway......
Thanks again for any info/help.
Roger
Old 08-06-2018, 09:06 AM   #4
Prof. of Pending Projects
wachuko's Avatar
2018 Tommy Bahama Interstate
Orlando , Florida
Metal valve stems, if not installed correctly, can leak air... this is the issue that I am having with one...
I now need to remove it, replace the rubber seals, and install them back with the correct torque settings (40lb-in i think, need to check before I tackle this)...
The hole/surface where the valves are inserted into, needs to be in good shape of the seals work...
Safe travels!
Wachuko
WBCCI #26769
2018 Airstream Interstate 3500 Lounge EXT Tommy Bahama w/ARS
wachuko is offline   Reply With Quote
Old 08-06-2018, 08:23 PM   #5
bobmiller1's Avatar
2005 34' Classic S/O
2006 39' Land Yacht 396 XL
north blenheim , New York
Itís possible that you may have a bead leak......
bobmiller1 is offline   Reply With Quote
Mercedes Van Executive Van Airstream Interstate eBay Watch Airstreams on eBay 0 05-14-2012 05:30 AM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 05-01-2012 11:00 AM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 04-19-2012 08:40 PM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 04-09-2012 05:40 AM
2012 airstream avenue class b van generator and a/c 190 camper van fully loaded eBay Watch Airstreams on eBay 0 03-29-2012 05:00 PM
