Old 09-07-2014, 10:43 PM   #1
Audible buzz in av system
We have a new 25 foot flying cloud and are just learning about using the radio and using our paired ipad and iPhone playing our iTunes. We have noticed a buzz that sounds like interference from somewhere. Any advice or can anyone tell us what is causing this?
Rhodies is offline   Reply With Quote
Old 09-07-2014, 11:28 PM   #2
Al and Missy's Avatar
2002 30' Classic S/O
Melbourne Beach , Florida
When do you hear the buzz? Only on shore power? Only on Bluetooth, or also on other sources? Do you have any fluorescent lighting? Dimmers? LED lighting? Try turning everything on and off and see if you can identify the source. Disconnect shore power and run on battery. You get the idea. Anything that uses power could be the interferer. Turn Bluetooth off on everything but one music source.
Interference problems are difficult to diagnose. Good luck!
Al
Al, K5TAN and Missy, N4RGO
2002 Classic 30 Slideout
S/OS #004
Al and Missy is online now   Reply With Quote
Old 09-08-2014, 06:38 AM   #3
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
If speaker wires are run too close to 120vAC wiring, it's not uncommon to hear a 60Hz hum. The cause is usually the induction current surrounding the 120vAC wiring, and the speaker wire acting as an antenna to pick up the induction current.
The best fix I know of is to reroute the speaker wires away from the 120v wires. If you can't reroute the speaker wire, you may want to replace it with shielded wire (which is not the same as insulated wire; insulation doesn't provide shielding).
Cats and ultraleather Airstream upholstery don't mix!
Old 09-08-2014, 06:57 AM   #4
BeachHouse's Avatar
2005 25' International CCD
Lilburn , Georgia
I eventually found my issue with buzzing was caused by a bad ground while on shore power. My power cord had a burned connection at both ends. I replaced the cord and the connection at the trailer and now no buzz. I had been trying to isolate the issue of speaker wires, sub woofer and all of the connections but didn't have any luck.
BeachHouse is offline   Reply With Quote
Old 09-08-2014, 07:40 AM   #5
Air Dog's Avatar
1995 36' Classic 36
Boulder , Colorado
My new solar charger has a desulfurization mode that was interfering with the av system. Connecting the charger directly to the battery solved that problem. I've also found that setting my iPhone near radios and even alarm clocks in hotel rooms can make them buzz. Don't know if it's the cellular signal or wifi. Its especially noticeable in the jets I fly. When they tell you to turn your electronic devices off for takeoff and approach, they are not just trying to be a PITA.
Air Dog is offline   Reply With Quote
air conditioner "buzz" anniem General Repair Forum 0 08-31-2014 07:19 AM
Mild Electrical Buzz (shock?) LavenderMoon Electrical - Systems, Generators, Batteries & Solar 9 07-22-2013 06:33 PM
faint buzz coming from suburban furnace saburkha Furnaces, Heaters, Fireplaces & Air Conditioning 5 03-10-2012 02:11 PM
The Airstream Really Creates a Buzz! redwoodguy On The Road... 17 01-10-2012 11:27 AM
what's that buzz? nettepdx On The Road... 14 02-01-2005 06:13 PM
