Old 09-12-2003, 11:21 AM   #1
Mark K's Avatar
Argosy rear air bag leveling valves.
Hello, I am new to this forum, and to my 1975 Argosy 26ft motorhome. I need to replace the leveling valves and linkage on the rear air bag setup. It is an American Carrier system, and the previous owner removed the linkage, and left the valves open to the elements. They also added a "pump-trol" pressure switch which does nothing but raise the vehicle up and down at all the wrong times LOL!, anyway, are the valves available? or seal kits for repairing them? As I mentioned, I also need the "arms" to connect the valves to the axle. Thanks.
Mark K is offline   Reply With Quote
Old 09-12-2003, 11:35 AM   #2
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
On a 75 this would have been an add on to the leaf spring suspension. My 76 is a leaf setup with shocks and no air at all. If it was retrofitted and is using the bags as the suspension your best bet is going to be a heavy duty truck supply place like fleetpride. They are all over the place. You may have to find some more part numbers, but they are willing to help.
Non of the manufacturers you mention sound familar to me, an I just got done going thru my 78 Argosy Air ride rear suspension.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 09-12-2003, 01:46 PM   #3
Mark K's Avatar
Thanks, it is the same setup I had on my 82 classic 28ft
I was told it was the standard setup for many years. Thanks
Old 09-13-2003, 12:47 PM   #4
Retired and Retreaded
edmatlock's Avatar
1972 26' Argosy 26
1978 28' Argosy 28
Oklahoma City , Oklahoma
Send a message via Yahoo to edmatlock
My '78 Argosy had the same problem with no control arms. You can make some with threaded rod. I removed everything and installed new air bags with air valves on each side of the coach.
No more air pump or control problems.
I have the original argosy book on the rear bags if you want a copy.
ED MATLOCK
edmatlock is offline   Reply With Quote
Old 09-14-2003, 04:26 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Ed- sounds like you did what I need to. My compressor has been dead for a year or more, and I can't replace it right now. I would love to know what you did to your to eliminate it, and how to to the same. thanks
Old 09-15-2003, 04:34 AM   #6
edmatlock's Avatar
1972 26' Argosy 26
1978 28' Argosy 28
Air Bags
I removed everything and ran the air lines to the outside of the coach. For now, you can install an air valve in the compressor line and use an outside air compressor. Hint:You can also install an air guage to monitor the air pressure at all times. The total cost: <$20.00.
ED MATLOCK
air bag air compressor dbyar Mechanics Corner - Engines, Transmission & More... 12 05-08-2004 12:58 PM
Searching for a rear air bag part number stuart2 Airstream Motorhome Forums 7 03-14-2004 01:15 PM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
