Join Airstream Forums Today
Old 03-02-2010, 05:40 AM   #1
1977 24' Argosy 24
seattle , Washington
Argosy MH floor redo!! Help!!
Hey ya'll. Been a while away from the site, but back with a passion!! Currently working on replacing the floor in my 77 Argosy 24' mh. Looking at my past posts, (search snowy23), you will know I bought a 77 shuttle bus that was revamped into a mh. (I found that out after the fact). Anyway, I started tearing into the bed area and found rotted flooring and the more I saw, the more I tore out!! Now the whole insides are out with the exception of the refrigerator/microwave cabinet. I'm about to replace all the flooring after I treat the floor support framing with por 15 among other stuff. My question is will removing the screws that run along the c channel down into the plywood sacrifice any integrity in the frame or body structure? I feel like cutting them off will definitely make the plywood easier to install without having to do much cutting. Just don't want to cut the screws if it means weakening the overall body structure.
Thanks for any heeeelllpppp! (didn't get any responses in the argosy forum).
snowy23 is offline   Reply With Quote
Old 03-10-2010, 11:02 AM   #2
1984 31' Airstream310
My take on the subject is you can probably cut the screws but you WILL need to replace them. Those screws are what hold the shell to the truck chassis. (assuming we're talking the same screws!).
From your description it sounds like you've pulled off the lower section of inner skin. The trick will be replacing the screws/bolts once you put the floor in place. You will have to have someone working from underneath while you work inside replacing the fasteners.
Hope this helps.
"Wherever you go... there you are." - Buckaroo Banzai
1986 345 Motorhome
1984 310 Limited Motorhome
1974 31' Excella trailer
1974 20' Argosy Motorhome - race car trailer tow vehicle
Old 04-09-2011, 03:24 PM   #3
1989 34.5' Airstream 345
Jamestown , Kentucky
Images: 13
Hello snowy23
How is Your project going ?
Or are you done.
John H. is offline   Reply With Quote
'74 Argosy redo mouth012006 All Argosy Trailers 64 06-06-2011 09:04 AM
An idea for '75 Argosy MH bathroom redo?? kdenault Argosy Motorhomes 3 01-30-2011 08:02 PM
Argosy/Shuttle Bus Redo snowy23 Argosy Motorhomes 0 02-26-2010 05:08 AM
good place for seams for a shell-on floor redo greenrig Repairing/Replacing Floor &/or Frame 10 12-13-2009 07:22 PM
Argosy floor out.. Happycampers Repairing/Replacing Floor &/or Frame 1 09-14-2004 03:20 PM
