Join Airstream Forums Today
Old 09-22-2010, 04:32 PM   #1
frankandsue's Avatar
Long Beach , Mississippi
Another reason to keep your Airstream Diesel Motorhome
Government Diesel Emissions Standards & RV’s
Posted By Mark Polk On September 22, 2010
I just returned from the Pennsylvania trade/public RV show and while looking at a new motorhome on a Freightliner Custom Chassis I noticed what looked to be a small fuel tank located under one of the outside storage compartment doors. The cap on the tank had the letters (DEF) which I later discovered stands for Diesel Exhaust Fluid. I had no idea what Diesel Exhaust Fluid was, so I headed over to the Freightliner display to find out. The Freightliner representative was extremely knowledgeable and helpful in explaining what DEF was, and after returning home I decided to research it a bit further.
It turns out DEF was a result from the latest rounds of EPA mandates on diesel engine emissions standards. These EPA mandates on diesel emissions have a long history. For over 25 years the EPA has aggressively increased stringent diesel exhaust emissions standards on manufacturers, most notably in the areas of Particulate Matter (PM) and oxides of nitrogen (NOx). These exhaust emissions are by-products of the combustion (or incomplete combustion) of diesel fuel. Think of the PM as the soot or smoke you see emitted from the exhaust system. Oxides of nitrogen result from a bad reaction between nitrogen and oxygen in the high temperatures created by the combustion process.
In 2000 the EPA signed emissions standards aimed at PM emissions, designed to take full effect by the release of 2007 model year vehicles. That brings us back to DEF and the 2010 EPA mandates, designed to reduce the amounts of nitrous oxide emissions released into the atmosphere.
As far as the RV Industry goes all but one Original Equipment Manufacturer (OEM) chose a process called Selective Catalytic Reduction or (SCR) to meet this new EPA standard. Simply put SCR adds a Diesel Exhaust Fluid into the exhaust gas and filters it trough a catalyst to convet NOx into nitrogen and water. This system is designed to remove additional PM and emissions from the diesel combustion process.
Pros & Cons of SCR
So what does all of this mean to the new diesel RV owner?
Pros:
1) SCR gives you 5% to 8% better fuel economy.
2) More torque & horsepower compared to a similar 2007 engine with Exhaust Gas Recirculation (EGR) technology.
Cons:
1) The owner will need to keep the DEF tank topped off, but this won’t be hard to do since DEF will be abundantly available at travel centers & auto parts stores.
2) It is possible for the DEF solution, made up of two-thirds part water, to freeze, but the DEF tank is insulated and the system uses heated lines to deliver the fluid to help avoid freezing during start up and normal operation.
3) DEF can degrade, but it would take 125 degrees of direct heat over a fairly long period of time, which is unlikely to ever happen.
4) If for any reason you do not refill the DEF tank and you run out the engine will decrease speed to approximately 30 mph until more DEF is added to the system again. There are gauges in the coach that will alert you in plenty of time to refill the tank before it runs dry.
5) Increased cost. As with all new technology the pricing will be affected, but the jury is out on whether the projected increased fuel economy will offset the increase in price over a period of time.
So like it or not, this is the system of choice being used by the majority of RV manufacturer’s to meet or exceed the 2010 EPA diesel emissions standards.
What’s next?
Get ready for the next round of EPA mandates. Now that the exhaust coming out of the tailpipe is probably cleaner than what is going into the intake (in many areas of the country) we need to brace ourselves for what is next. It looks like the next government approved EPA and DOT mandates are aimed at increased fuel economy and Greenhouse Gas (GHG) emissions. These new diesel emissions standards will be phased in between 2014 and 2018.
The new standards being imposed are sure to dramatically increase the cost of a diesel powered motorhome again, and the question begs will the ends justify the means? I guess we’ll have to wait and see.
Happy Camping,
Mark Polk
Frank & Sue
frankandsue is offline   Reply With Quote
Old 09-22-2010, 06:48 PM   #2
Hansom-Man's Avatar
2009 23' FB Flying Cloud
The Woodlands , Texas
Wow, very informative.
Thanks for the explanation. NOx emissions are probably the number 1 topic on the EPA hit list. This is the first thing they always watch the energy producers for when applying for new construction permits.
I suspect the cost of this "upgrade" will pale in comparison to the additional taxes placed on the demographic purchasing these type of vehicles.
Hansom-Man is offline   Reply With Quote
Old 09-22-2010, 09:02 PM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Yup. And I thought my 2006 Gee-Em was hobbled with enough mileage robbing emissions equipment.
Go to 'Search.' Select 'Advanced Search.' Keyword 'urea.' Scroll down and select 'Show Results as ... Posts.' And then 'Search Now.' You will find 47 posts at AIR about this recent addition to diesel particulate control. That will lead you to the threads (and many more than 47 posts) where this topic is noted.
But yes ... thanks for giving us chapter and verse on what the journos are telling us about how lucky we are to live in the updated brave new world.
5 meter Langford Nahanni
Old 09-22-2010, 10:38 PM   #4
Maniacal Engineer
barts's Avatar
Menlo Park , California
I commute to work in a 2009 Jetta diesel - 0-60 mph in under 8 seconds, and 40+ mpg at 70+mph. Yes, it has a urea injection system. Seems to work, and I like it that the exhaust doesn't smell like a bus.
I remember all the comments when I bought my PowerStroke in '96 about the electronic engine controls, etc.... I've had nearly 170K trouble free miles; the only unscheduled maintenance was a burst power steering hose when it was held against the stops too long.
When I buy a new truck someday, it will have lots of systems to help keep the air we all breath clean and free of particulates. That's fine - like taxes, it's everyone's job to chip in.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 09-23-2010, 06:15 AM   #5
DEITZ645's Avatar
2006 30' Classic S/O
1987 34' Excella
Mohrsville , Pennsylvania
Images: 99
Luckily my '06 diesel truck and '06 Jetta TDI are pre the ultra low sulphur and urea diesel fluid mandates, but when I go to purchase my next diesel I guess I will have to pony up for the new technology.
I googled diesel exhaust fluid to see what is costs and it looks to range from $12.00 - $20.00 / 2.5 gallons. Does anybody know how many miles to the gallon one gets out of this stuff?
Carl, Elaine & Bailey Beagle
2006 30' Classic W Slide & Limited Package Katarina
1987 34' Excella 1000 Double Door Savannah
2006 GMC 2500 HD 6.6 Turbo Diesel Crew Cab 8' Bed
TAC PA-3
AIR #14487
WBCCI #7429
NQ3U (was KB3UOM)
DEITZ645 is offline   Reply With Quote
Old 09-23-2010, 06:21 AM   #6
DEITZ645's Avatar
1987 34' Excella
Images: 99
I may have answered my own questions. I found this F.A.Q. that has some good information.
Q. How much DEF will a truck consume?
A.
DEF consumption is expected to be approximately 2 to 3% of fuel consumption, depending on vehicle operation, duty cycle, geography, load ratings, etc.
Q. What is the number of miles a truck can expect to travel on one gallon of DEF?
A.
DEF consumption is directly related to fuel consumption. A truck averaging 6 MPG can expect to go approximately 300 miles on one gallon of DEF.
TAC PA-3
AIR #14487
WBCCI #7429
NQ3U (was KB3UOM)
Airstream Diesel Motorhome eBay Watch Airstreams on eBay 0 07-19-2010 08:50 AM
Airstream Diesel Motorhome eBay Watch Airstreams on eBay 0 06-28-2010 12:30 PM
Airstream Diesel Motorhome eBay Watch Airstreams on eBay 0 06-18-2010 02:20 AM
Airstream Diesel Motorhome eBay Watch Airstreams on eBay 0 06-04-2010 11:10 PM
Airstream Diesel Motorhome eBay Watch Airstreams on eBay 0 05-25-2010 10:40 PM
