Old 09-24-2017, 01:16 PM   #1
1982 31' Airstream 310
Amsterdam , Nederland
Airstream 310 with BB-454 fuel mileage
Hello Guys,
I am interested in how much is your fuel consumption for your eighties Airstreaam 310 equipped with Chevy Big Block 454 engine. I am considering buying one, and this would be really a decisive factor to rebuild the 454 or replace with a modern one. Appreciate your help with this. Thank you.
Peter
peteralbert is offline   Reply With Quote
Old 09-24-2017, 02:29 PM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
7mpg if you are lucky.....add an overdrive and convert to autogaz rather than changing the engine in Europe, you will maybe get 8-9mpg but autogas is half the cost of petrol over here. If the engine needs changing then then look for a donor truck with a 8.1Vortec/Allison trans
martin300662 is offline   Reply With Quote
Old 09-24-2017, 04:16 PM   #3
Dazed and Confused
Isuzusweet's Avatar
Hillsburgh , Ontario
What's that saying.....if your first question concerning the purchase of a 14,000 lb 7.4L 454 carbureted powered 80's RV is, "what kind of mileage will I get?"........
They did make a turbo diesel option, like mine, which gets considerably better mileage.
Cheers
Tony
Its a recession when your neighbor loses his job; its a depression when you lose your own. "Harry S Truman"
Old 09-24-2017, 09:06 PM   #4
2007 22' International CCD
I suspect the real question is "What mileage...". Oh, sorry, that was a statement....
Old 09-25-2017, 05:44 AM   #5
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Originally Posted by peteralbert View Post
Hello Guys,
Peter
If you are planning on crossing the Alps, 3-5mpg, otherwise 6-8.
The anticipated amount of miles driven needs to be in the equation, if you are trying to save money.
1991 25' Excella Trailer
1990 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 09-25-2017, 11:20 AM   #6
Grosspoluter's Avatar
Franklin Park , Illinois
Mpg
I agree with what PeterH said
I own an airstream 345 with the 454 V8 carbureted engine
I live in Illinois and drive it primarily in Illinois in a little bit Wisconsin, 8 miles to the gallon is about the best I get.
Usually it's closer to 5 to 6 MPG
Grosspoluter is offline   Reply With Quote
Old 09-25-2017, 12:42 PM   #7
WayneG's Avatar
1984 27' Airstream 270
Scotia , New York
Last trip: I90, Mass Pike, Hills included, about 300 miles round trip.
1984 27 footer 454 with TBI, towing about 2500 pounds of trailer with 4 wheeler.
I measured 7.3 MPG
Edit to add, I did use the generator for about 2 hours, but that should be less than a gallon for that, 38 gallons for the trip
WayneG is offline   Reply With Quote
Old 09-25-2017, 12:47 PM   #8
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
All the above.
And, changing to another gas engine won't help.
Careful planning and execution of an upgrade to diesel may help some, but the cash spent to complete the swap will purchase a LARGE amount of gasoline.
Unless one drives a lot of miles, I doubt an return-on-investment would be reached.
With no intent to insult anyone, I agree with the posts above: If the first question is about MPG, a vintage motorhome may not be the best choice.
The costs of repair and maintenance are more worrisome than fuel.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 09-25-2017, 01:49 PM   #9
Boom Sounds's Avatar
1991 25' Airstream 250
Oxford , Oxfordshire
UK gallon is obviously different to US. I reckon I get 14 from my 454 tbi 4l80e overdrive on a nice run in France.
Peter is right, the mountains are horrific (for fuel consumption) and exhilarating in equal measure
Boom Sounds is offline   Reply With Quote
Old 09-25-2017, 01:50 PM   #10
LPG is the way to go in Europe
Old 10-11-2017, 03:14 AM   #11
1986 34.5' Airstream 345
Glencoe , Oklahoma
7 MPG here on average towing my Jeep. Newer RVs don't do much better, my Ford Class C got about 5 MPG. It was fuel injected and much smaller, 460 engine though. Some of the modern RVs are reported to get about 12 MPG, not worth the trade off compared to driving one of these!
JJ1965 is offline   Reply With Quote
Old 10-12-2017, 01:01 AM   #12
transmission?
so then as I see it is not really the engine, but the transmission/overdrive that could help to improve MPG, correct?
Additionally to consider changing to LPG , which is not really an opion. Otherwise retrofiting an injector...
Old 10-12-2017, 04:20 AM   #13
WayneG's Avatar
Scotia , New York
Best & cheapest thing for better MPG is a well tuned engine, minimum weight on board, and reasonable speed.
Any modifications you do trying for better performance that go over $1000 will likely take you years to recoup.
I replaced my carb with TBI fuel injection. That cost me a bit over $1K. If anything, I may have a 1 to 2 MPG increase, but for me the value was in improved engine response and instant starting.
Others upgrade their tranny and get good results but again, a MH is already a money pit to maintain, once you start upgrades, chose wisely!
If you plan to go to town with the project, hopefully you have unlimited funds, and a understanding copilot/family.
Old 10-12-2017, 04:49 AM   #14
Keen amature
1975 20' Argosy 20
Chestfield , Kent
Wayne, based on peteralbert's location this really isn't the case. In Europe LPG costs half gasoline. Current average gas prices in Nederlands is 1.59/L vs LPG at 0.71/L. Assuming 7mpg (US gallon) is basically 2mpL so switching to LPG saves 0.44/mile if the mileage is not degraded by the switch.
Isuzu fuel mileage shepherd57 Classic Motorhomes 20 01-26-2013 10:34 AM
Increasing fuel mileage ITowSilver Tow Vehicles 11 09-13-2006 09:31 PM
Towing Fuel Mileage fastrob Towing, Tow Vehicles & Hitches 62 05-01-2006 06:34 PM
Fuel Mileage ??? slow-canoe General Motorhome Topics 20 10-08-2005 04:20 PM
454 High Mileage fcycle Mechanics Corner - Engines, Transmission & More... 8 04-21-2004 02:42 PM
