Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
User Name
Password
Portal Register FAQ Members List Rally Calendar Chat Room Mark Forums Read
Welcome to the AIRForums.com the community where Airstream enthusiasts meet online. Our members have contributed over 30,000 pages of information about Airstream Trailers & Motorhomes.
You are currently viewing our site as a guest which allows you to read most all of our content. By joining our community (For FREE) you will have access to participate in the discussions, post new topics, connect and communicate with other members, respond to polls, upload your own photos, post classified ads and access many other special features.
Registration is fast, simple and absolutely FREE so please join our community today!
Click Here to Register!
- Monthly Newsletter
Old 08-19-2002, 05:03 PM
dienst1
dienst1's Avatar
Profile:
1981 Airstream Excella Univolt
Does anyone know the rated output of the Univolt in a 1981 28' Excella motorhome? I am considering replacing it with a Prosine 1000 Inverter rated at 1000W continuous/1500W surge. Peak output is rated at 25 amps. I would like to mount it in the current space occupied by the Univolt, under the bed. Space limitations in that location make The Prosine 1000 the largest Prosine unit that is safe to install.
Dick
Get rid of these ads... register today, it's FREE
Old 08-20-2002, 09:05 AM
thenewkid64
Just a member
thenewkid64's Avatar
Profile:  Tampa Bay, Florida
Dick,
I think the univolt output is 50 AMPS???
Some food for thought. 2 batteries will make the 25 AMP charging output 12.5 AMPS per battery. The worry here could be a slow charge on the battery after a full discharge can be detrimental to the life of the batteries. If I remember correctly the batteries are under your steps, the distance between the batteries and the inverter should be as short as possible. If you are planning on running the inverter off the Alternator you may also want to consider larger cables from the alternator/isolator to the battery/inverter. Number 1 or 0 would be best. Also as a saftey device I highly reccomend a 250 AMP Fast blow fuse betwen the battery and inverter and the Alternator and the battery. The main reason for this is safety in case of a short. Many of the inverters I ahve worked with have a 40 AMP chargers. That is what the Trace 1200 inverter I had was equipped with. I was able to recharge 2 batteries fine with it, but I also had 4 solar panels at the time. I was able to run most everything(not the AC)including a bread machine.
Brett G
WBCCI #5501 AIR # 49
"Stop worrying about the potholes in the road and celebrate the journey." -- Fitzhugh Mullan
Wise men talk because they have someting to say; fools, because they have to say something. -- Plato
In politics, absurdity is not a handicap— Napoleon
vB code is On
Pingbacks are On
Questions-31' 1981 Excella Sharon Lee 1981 - 1983 Excella 6 01-07-2006 06:43 PM
1981 airstream excella diesel motorcoach jenia@mundomotors.com Airstream Motorhome Forums 1 03-21-2004 05:11 PM
1981 Airstream Excella Diesel dienst1 Airstream Motorhome Forums 6 10-02-2003 04:45 PM
Help find the weight of a 1981 31foot Excella Sharon Lee Our Community 8 06-18-2002 08:55 PM
airstream! airstream! airstream! 83Excella Our Community 0 03-23-2002 10:37 PM
Powered by vBadvanced CMPS v2.1.0
Powered by vBulletin® Version 3.5.8
SEO by vBSEO 3.0.0
Airstream is a registered trademark of Airstream Inc. All rights reserved.
Airstream trademark used under license to Social Knowledge LLC.
Wikipedia about Airstream - Airstream Central - Airstream Photos
