Old 11-19-2002, 08:41 PM   #1
shelocta's Avatar
1990 25' Excella
Pflugerville , Texas
Access to MH Heater
Hi everyone;
As anybody tried to remove the passenger side panel that covers the heating and A/C on a 1982 or thereabouts motorhome. The manual says that you remove one screw and you can pull it out and they advise you to pull really hard. I keep looking at this darn thing and I see no way of doing it without pulling off the trim on the passenger side to get clearance so it will come on out. Perhaps the guy that was writing the manual is thinking about how they put it in at the factory before they added all the trim. If anybody has any ideas on this I would appreciate it.
Regards
Bill
Give me 40 acres and I'll turn this rig around.
shelocta is offline   Reply With Quote
Old 11-23-2002, 05:50 AM   #2
The manual is correct. I have removed the panel and you have to pull hard. The first time I did it I removed the trim which was not necessary.
Howard Lefkowitz is offline   Reply With Quote
Water heater and furnace need work? goodgrey Water Heaters, Filters & Pumps 18 04-15-2006 10:29 AM
How is your Heater Core on MH? RonJudi General Motorhome Topics 7 01-26-2004 08:17 PM
wiring - water heater Craig Electrical - Systems, Generators, Batteries & Solar 12 10-02-2002 05:03 AM
