Old 03-08-2004, 09:58 PM   #1
Jim Tyrney's Avatar
Question '86 345 AS MH Interior Molding
In my 86 345 AS MH, the plastic molding between the front roof over the driving area and the roof over the living area where they join together, the molding is cracked due to some pop rivets that have come loose and pushed thru. Is there a source for this molding and how is it removed? This molding is approx. 1/2" to 3/4" wide, running from the drivers side, up overhead and down to the passenger side. It looks like the molding is attached to a metal rail that is pop riveted ( these are the ones that have came loose) to the overhead. Thanks for any input on this project. Jim
"Property doesn't have rights, people have rights to property"
Jim Tyrney is offline   Reply With Quote
Old 03-09-2004, 06:13 AM   #2
LOST , Hawaii
I am not exactly sure what yours looks like, I have been using this on window, door, and panel edges.
John
74Argosy24MH is offline   Reply With Quote
Old 03-09-2004, 06:41 AM   #3
RivetAddict
swebster's Avatar
1986 34.5' Airstream 345
Louisville , Kentucky
Jim,
Mine did the same thing. I"ve removed it during my interior remodelling. It's a black plastic cap that fits over an aluminum strip that's pop riveted to the ribs.
I don't know where you would get this on the aftermarket since it's so specific. Perhaps you could try Airstream.
I removed mine my drilling out the pop rivets. I plan to replace it with a simple aluminum 3/4" wide extrusion and just pop rivet it back into place.
Steven Webster
1986 Airstream 345 Classic Motorhome
AIR 1760
swebster is offline   Reply With Quote
interior skin molding and rivets kokomoscalls General Interior Topics 1 03-19-2014 12:09 PM
T-Molding (Tee Molding) Trouble and Solution! shane_franz Cabinets, Counter Tops & Furnishings 0 07-05-2013 12:09 PM
Help finding Interior Molding Steve Finch Upholstery, Blinds, Walls & Interior Finishes 6 07-01-2012 09:31 AM
Avion interior molding, trim M2HB Upholstery, Blinds, Walls & Interior Finishes 3 06-11-2012 07:49 PM
Black Molding 1988 345 nellie1960 Classic Motorhomes 2 08-02-2010 05:54 AM
