Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Motorhome Forums
Old 05-10-2003, 03:29 PM   #1
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Exclamation '84-'85 345 advisory
While fixing my rear bed support, I noticed that a screw was wearing a hole in the side of my white water tank. The screw was from the generator automatic interrupt box in the left rear compartment.
My advice is to check your set-up and make sure the screw is not damaging your tank.
I am assuming that the interrupt box was a factory install. I'd be interested in knowing if anyone else had this situation.
ViewRVs is offline   Reply With Quote
Old 05-10-2003, 03:55 PM   #2
ViewRVs's Avatar
1977 20' Argosy 20
Here's a photo that might help explain the situation. There is a partition between the compartment and the tank. It's that partition that the transfer box was screwed to.
Name:	02_as bed c.jpg
Old 11-14-2013, 05:21 PM   #3
1973 Argosy 24
Frostproof , Florida
From our '73 Argosy 24 we pulled the white water tank to discover the frame itself has nearly warn through the tank wall. The floor below had deteriorated that much so that friction was able to wear and it looks like actually melt the tank wall. Tank does not leak (yet), and, of course, we'll replace the floor under the tank and gaucho. Must we replace the tank or is it safe to use now that the wear is stopped? Thanks for your opinion.
Carolinda
1973 Argosy 24
TV - 2011 Tundra
Now at the getting much prettier stage!
Carolinda is offline   Reply With Quote
345 Motorhome :: 2011 Airstream 345 cowboy7877 Airstream Registry Discussions 0 12-27-2011 03:38 PM
I 40 through Knoxville advisory GreggH On The Road... 0 05-03-2008 09:41 PM
Minneapolis Travel Advisory markdoane On The Road... 2 08-01-2007 10:22 PM
Storm advisory with hail warning Boondocker Off Topic Forum 12 02-16-2006 09:48 PM
345 Hill Climbing ViewRVs Mechanics Corner - Engines, Transmission & More... 12 04-18-2002 11:52 AM
