Old 07-12-2002, 09:43 AM   #1
Bfrank's Avatar
1979 24' Airstream Excella 24
Adams , Tennessee
'83 - 310
Maybe someone has had a simular problem my 310
has gotten cleaned up inside and I have been running it in the
driveway I have noticed that the fuel and voltmeter guages are
peging out past full on the fuel and off the scale on the volts
when the thing is running I put a digital vom on the batteries
while it was running and measured 13.5 volts so it seems that
the alternator is working properly but I have yet to look for the
usual blown fuses or connections just wondering if anyone has seen these symptoms before and what the cure was. I will have
a chance to dig deeper into it later just thought I would try to pick someones brain on this forum before I dive into it. I did notice that the temp guage is working without this little problem
Bfrank is offline   Reply With Quote
Old 07-12-2002, 12:59 PM   #2
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
You could try to isolate the ground wire of the gauges and run them directly to a solid ground on the body.
1991 25' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
1982 turbo diesel 310 :: 2013 Airstream turbo diesel 310 mayco Airstream Registry Discussions 1 07-28-2015 11:58 AM
repower 310 Turbo joepospisil Mechanics Corner - Engines, Transmission & More... 10 11-07-2003 07:33 AM
Screen door for 310 MH kzener40 Airstream Motorhome Forums 1 06-14-2002 10:21 AM
1985 310 found off road ViewRVs General Motorhome Topics 1 05-27-2002 12:15 PM
