It also depends on the leveling valve(s), If you have one valve then the coach should ride level beacuse the air bags will be filled to the same lift point. If there are two valves then you could either have a bad valve or need to adjust the one that is a bit down.
I would measure from the ground to the top of the bag mount to determine the setting of the level valves.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
