I doubt if there is another fuse. You might look for a solenoid close to the hydraulic pump or mounted directly on it.
First thing would be to see if any voltage is getting to that solenoid when you try and lower the jacks. If no voltage then you'll have to start back tracking from there.
If there is voltage you might try tapping on the solenoid. If that doesn't work then try replacing the solenoid. If that doesn't do it then the only thing left is the pump.
Do you have the wiring diagram for the jacks?
1975 24' Argosy Motor Home
