I finally got a scanner and scanned the wiring diagram for my '75 Argosy chasis (P30 Chevy). Here are the links to the scans:
http://www.theoriginalhayseed.com/19...30_wd_left.jpg http://www.theoriginalhayseed.com/19..._wd_middle.jpg http://www.theoriginalhayseed.com/19...0_wd_right.jpg http://www.theoriginalhayseed.com/19...30_wd_alt1.jpg http://www.theoriginalhayseed.com/19...30_wd_alt2.jpg
NOTE: these links are case sensitive.
NOTE: there is also a set of .bmp files under the same name if you prefer them.
NOTE: these files are BIG ... 1.5 meg each !!
When you click on these links the results may vary depending on the browser you use. I found the best way to look at or print them is to 'save them to disk' then look at them locally on your PC. The best program is probably the Windows Imaging program (click 'Start', click 'Programs', click 'Accessories', click 'Imaging')
If you have trouble, eMail me (dsawvel@skybest.com) and I'll send you a set.
