Old 07-06-2013, 02:48 PM   #1
Lido&Linda's Avatar
1985 34.5' Airstream 345
Chino , California
12 volt converter charger
what brand or type should i replace the original univolt that i have now on my 345 ?
The Unleaded Zeppellin
Lido&Linda is offline   Reply With Quote
Old 07-06-2013, 03:12 PM   #2
1974 Argosy 20
Kooskia , Idaho
I have always liked the Progressive Dynamics PD 92xx series. The one which would probably be best for you would be the 9260 (60 amps) but a 9245 (45 amps) would probably work. Since you have a good sized built in generator, if it were mine, I would go with the 9260. The battery capacity of your 345 is probably two type 27's or 29's and much more charging capacity could be to fast an initial recharge for them, so I would not go larger. The charge tapers off pretty fast, so the absorption rate is usually under 40 amps, that is why I say even a 9245 would work for you.
There are other options (manufacturers) and many will recommend talking to Randy at Best Converters for his opinion.
Old 07-06-2013, 11:51 PM   #3
Lido&Linda's Avatar
Chino , California
Does the 9260 have a smart charger ? so i can leave the battery charger on ?
Old 07-07-2013, 10:04 AM   #4
Yes, it is a smart charger and a very good one at that.
Old 07-08-2013, 10:24 PM   #5
Lido&Linda's Avatar
Chino , California
thanks everybody.Now how many amps should i get?Also how do get access to it,seems so small space under the oven cant really see how i can get it out?
Old 07-08-2013, 11:00 PM   #6
I just installed a PD 9260, took less than 30 mins to install since my 12volt breaker panel And wiring is still in great shape.
No more voltage dips and my fans and water pump seem to run better.
About 1/3 of the weight of the Magnetek boat anchor.
0557 is offline   Reply With Quote
Old 07-09-2013, 10:20 AM   #7
Lido&Linda's Avatar
Chino , California
may be its easier because you have a trailer,anyone did a 345 where the univolt is under the oven?
Old 07-10-2013, 07:05 PM   #8
ViewRVs's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to ViewRVs
Based on Brad's recommendation, I just replaced mine with the Progressive Dynamics unit. I went with the 45 amp version since my unit isn't that big and I only have one house battery.
ID:	190665   Click image for larger version
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives @ ViewRVs.com
ViewRVs is offline   Reply With Quote
Old 07-10-2013, 07:15 PM   #9
Now you did it...you just jinxed yourself
Old 07-10-2013, 07:32 PM   #10
ViewRVs's Avatar
1977 20' Argosy 20
So far, so good! It is putting out a consistent 13v when on shore power!
Fred H.
Old 07-13-2013, 11:56 PM   #11
Lido&Linda's Avatar
Chino , California
well i finally get to the bad power supply.i had to un screw the stove and slide it foward to gain access to the power supply. its a 50 amp so i will order a 60 amp just to have more power in case i add more accesory like high amp sound system.
Old 07-14-2013, 10:17 PM   #12
3 Dog Nite's Avatar
1989 34.5' Airstream 345
Cleveland , Tennessee
We installed the Progressive Dynamics PD9245 in our 345 MH. It worked out well as we fulltimed for 2 years after replacing. We just mounted it inside the power distribution box that the old one was in. Here's a link.
"Sometimes I wonder if the world is being run by smart people who are putting us on, or by imbeciles who really mean it." Mark Twain
AIR 22749 WBCCI 2349 NOVA TAC TN-6
1989 345 LE Classic Motorhome
3 Dog Nite is offline   Reply With Quote
Old 07-15-2013, 01:53 PM   #13
Lido&Linda's Avatar
Chino , California
thank you for the respond i guess i made the right desscition to order progressive dynamic and do you think i over kill to use a 65 than a 50 watt?
Old 10-21-2013, 12:44 PM   #14
wxbuoy's Avatar
1991 35' Airstream 350
Carriere , Mississippi
Send a message via Skype™ to wxbuoy
I also was looking to replace mine as well. Spoke with 3 Dog Nite a while back about his replacing the converter/inverter part of his Energenius.
Just spoke to Randy and he suggested the Powermax Boondocker for my 350. Thanks tot he great pics posted by 3 Dog Night and the model he got, I was able to extrapolate and see that Boondocker would fit.
Since I was at it I also picked up the trimetric battery system monitor. I liked the fact that I can get the data on the house batts as well s a volt reading on the starting battery.... The panel installed is about useless. Actually it is worse then useless since it leads you to assume it is even remotely accurate.
Hopefully I can install it on the rainy days that I can't be doing other stuff in/on the MoHo.
Dave and Felicia
wxbuoy is offline   Reply With Quote
12 volt
