Join Airstream Forums Today
Old 05-19-2003, 10:46 PM   #1
100 PSI or 70 PSI? '92 300LE
Dealer put 100 PSI everywhere and the coach is trying to rattle itself to death. Bridgestone 19.5 duals in back say max load at 110, Michelins in front say max load at 90, manual says 60 in rear...70 in front. What does experience say??
fangthorpe is offline   Reply With Quote
Old 05-20-2003, 05:40 AM   #2
Fred's Airstream Archives
1985air345's Avatar
1977 20' Argosy 20
Charleston , West Virginia
Send a message via Yahoo to 1985air345
Most of the Airstream classic MH's have 75 psi in the front and 60 psi in the rear tires. Anything higher than that is a rough ride in my 345.
Fred H.
1977 Argosy 20' Motorhome
Fred's Airstream Archives - Motorhomes
Fred's Airstream Archives - Trailers
1985air345 is offline   Reply With Quote
Old 05-20-2003, 07:17 AM   #3
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
tire pressure is a big question. i run 80 in the rear and 85 in the front . rides good. but i had my tires trued as they were out of round. the front tires were goodyear G195 8R19.5 BRAND NEW BOTH OUT OF ROUND. i dont know if there is a shop near you but that could check your tires . but i would bet your problems is out of round. and probably out of balance. i put the centri matic tire balancing units on my coach (sold by camping world) and it dont viberate at all. lol
al
wb13798 is offline   Reply With Quote
Old 09-01-2009, 11:49 AM   #4
1992 30' Airstream 30
roseville , California
tire pressure
Hi, I also have a 92 300LE My manual say 70 f 60 r also. That's how I am gonna run em till I hear some better advice.
prayerwheel is offline   Reply With Quote
Old 09-16-2010, 08:45 AM   #5
1985 34.5' Airstream 345
Elmendorf , Texas
Refer to the tire psi rating range instead of the motorhome manual. Usual 10-15 pound or less than the max rating is a good starting place. Ride, fuel economy, and tire life are other factors. More importantly check tire pressure on a regular interval.
pcbueg is offline   Reply With Quote
Old 09-16-2010, 10:11 AM   #6
BEWARE of the CAT
w7ts's Avatar
2010 31' Classic
Longmont , Colorado
I do not agree that picking some arbitrary amount less than tires max pressure is a good way to do it.
Tire manufacturers publish charts for their tires. It gives the appropriate pressure for various weight loads.
The first thing to do is weigh the vehicle configured as it is going to be used. Then find the appropiate pressure for that weight load in the tire manufacturer's specs . Then use that pressure in your tires.
Regards,
Ken
w7ts is offline   Reply With Quote
Serpentine Belt Question -'92 454 - HELP fangthorpe Mechanics Corner - Engines, Transmission & More... 17 07-25-2010 10:26 AM
Sagging Door in '92 300LE fangthorpe Airstream Motorhome Forums 3 12-30-2003 02:02 PM
Perfect Paint Scheme For '92 fangthorpe Airstream Motorhome Forums 6 11-27-2003 09:58 AM
Shurflo regulator_50 psi is not 40 femuse Water Heaters, Filters & Pumps 6 03-28-2003 09:54 AM
'92 Excella literature wanted Mark Wiltrakis Our Community 7 11-17-2002 12:47 AM
