Old 09-02-2014, 02:59 PM   #1
Hardworking's Avatar
1964 19' Globetrotter
Duluth , Minnesota
What is it worth 1964 globetrotter
just checking for help on value.
Looking to sell my 1964 globetrotter.
new items
tires
breaks
water heater
heater
gas piping
pex water piping
foam caution's
all fabric
all the wood front to back
counter tops
fridge (newer)
propane tanks
wiring with fuse box
out side shell in polished and no dents. veryfew miner scratches
only thing original are stove (works) and shower and toilet (works)
Hardworking is offline   Reply With Quote
Old 09-02-2014, 04:17 PM   #2
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
Pictures would help, but a few additional questions:
Did you replace the axle (I am assuming it is a torsion suspension)?
When you say you replaced wood front to back, are you talking the subfloor, finished floor, cabinetry, or all of the above? Did you lift the shell?
Any frame repairs?
Have you retrofitted grey tanks?
Is the converter original, or something more modern?
Does it have an air conditioner? If so, is it original, or newer?
Is there an awning?
Jonathan
Old 09-03-2014, 09:54 PM   #3
Duluth , Minnesota
Then globetrotter has no ac
The floor was patched with new wood and car bondo by the door
New wood to all cabinets
The converter box is new
The axel is original, and I have used the camper for two years while I worked on to and travels well.
Grey water tank is original too
And new awning too
Thanks for your help
Pictures will be posted tomorrow
Old 09-03-2014, 10:06 PM   #4
Belegedhel's Avatar
Houston , Texas
I'm looking forward to seeing some pics!
Old 09-03-2014, 10:26 PM   #5
Duluth , Minnesota
Pictures if this works?
Old 09-04-2014, 08:45 AM   #6
Belegedhel's Avatar
Houston , Texas
Doesn't look like it worked...
Old 09-04-2014, 04:54 PM   #7
Duluth , Minnesota
here is one of the outside.
Old 09-04-2014, 05:26 PM   #8
Duluth , Minnesota
outside of camper
Old 09-04-2014, 05:55 PM   #9
toastie's Avatar
1955 22' Safari
Great Lake State , .
How is the black tank?
toastie is offline   Reply With Quote
Old 09-04-2014, 09:01 PM   #10
Duluth , Minnesota
The black water tank has been used twice since I bought it.. I would say it work but may be a small leak.. Or operator error .. I am learning how to do everything. ..?
Old 09-04-2014, 09:05 PM   #11
toastie's Avatar
1955 22' Safari
Any pictures of the inside ?
Old 09-05-2014, 09:52 AM   #12
Duluth , Minnesota
Name:	ImageUploadedByAirstream Forums1409928556.264598.jpg
ID:	220861Click image for larger version
Name:	ImageUploadedByAirstream Forums1409928607.550230.jpg
ID:	220862Click image for larger version
Name:	ImageUploadedByAirstream Forums1409928636.358943.jpg
ID:	220863Click image for larger version
Name:	ImageUploadedByAirstream Forums1409928656.216316.jpg
ID:	220864Click image for larger version
Name:	ImageUploadedByAirstream Forums1409928674.820634.jpg
ID:	220865Click image for larger version
Name:	ImageUploadedByAirstream Forums1409928695.420505.jpg
ID:	220866Click image for larger version
Name:	ImageUploadedByAirstream Forums1409928715.334192.jpg
ID:	220867Click image for larger version
Name:	ImageUploadedByAirstream Forums1409928733.032282.jpg
Before and after pictures
Old 09-05-2014, 10:11 AM   #13
vinstream's Avatar
1962 19' Globetrotter
1963 19' Globetrotter
1961 19' Globetrotter
Wheat Ridge , Colorado
Based on year size and shape this trailer I believe should be priced around $18,000. The concerns to a potential buyer would be floor root and axles.
www.VINSTREAM.com
Wheat Ridge, Colorado
WBCCI # 1962
Instagram #Vinstream
vinstream is offline   Reply With Quote
Old 09-05-2014, 10:20 AM   #14
Duluth , Minnesota
Name:	ImageUploadedByAirstream Forums1409930304.361438.jpg
ID:	220873Click image for larger version
Name:	ImageUploadedByAirstream Forums1409930327.329801.jpg
ID:	220874Click image for larger version
Name:	ImageUploadedByAirstream Forums1409930354.646875.jpg
Floor is real solid
1964, 1964 globetrotter
Is it worth it? Fun-Lovin 1974 - 1979 Sovereign 0 08-09-2003 10:50 AM
Any newbie worth his/her salt should be able to figure this out for her/himself... Dave Jenkins Our Community 4 07-26-2003 06:41 AM
Zip Dee Chairs - Worth it? j54mark Our Community 9 07-23-2003 11:34 AM
Picture worth a thousand words! dinoburb On The Road... 1 01-13-2003 09:43 AM
Worth a look... canny_banjo_man Airstream Motorhome Forums 4 11-12-2002 10:34 AM
