Old 03-29-2009, 12:16 PM   #1
1963 19' Globetrotter
Cedar Crest , New Mexico
Water tank replacement - 1963
Greetings AS folks!
I just discovered that my original steel water tank has rusted out. It's time to consult the oracles. I mean the forums. Patching or repairing the tank doesn't look like a great idea. I need your advice. I'm planning to stick with the original configuration, with a tank under the goucho bed. Should I look for ABS or polyethylene? Seems like a reasonable do it yourselfer. What about a filler? Can I reuse the original? Any other thoughts and advice welcome. Cheers!
elywhy is offline   Reply With Quote
Old 03-29-2009, 03:16 PM   #2
byamcaravanner's Avatar
1967 28' Ambassador
1970 29' Ambassador
Waukesha , Wisconsin
Even though the poly tanks are cheaper, I would recommend the ABS. You will be able to apply fittings to the ABS tank as required without any special tools. You may be able to retrofit the original fill tube depending on the tank you pick. Valterra makes ABS water tanks in a number of sizes.
Keep in mind that the original Galvanized steel tank was a pressurized system and the ABS/Poly tanks will utilize a demand pump rather than a pressure pump.
Happy Trails!
Steve & the crew
'70 Ambassador International Twin
'63 19' Globetrotter TAC WI-1
http://byamcaravanner.blogspot.com/
byamcaravanner is offline   Reply With Quote
Old 03-31-2009, 09:34 PM   #3
Thumbs up
Thanks Much. I appreciate our suggestion. I haven't found a tank of the right dimensions, yet. But ABS makes sense. Cheers!
Water tank drain valve replacement lboyd Fresh Water Systems 5 12-31-2011 02:51 PM
1963 Sovereign water tank question Rollerboy Fresh Water Systems 1 11-06-2011 10:56 AM
Fresh Water Tank Location & Size VeggieBullet Plumbing - Systems & Fixtures 9 10-20-2011 05:23 PM
Removal of 1973 fresh water tank Belegedhel Fresh Water Systems 6 08-05-2011 07:32 AM
Fresh Water Tank mshamilton Plumbing - Systems & Fixtures 4 05-08-2011 02:01 PM
