Old 01-29-2010, 01:16 PM   #29
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
Originally Posted by goransons View Post
Rick, how's the project coming along?
Well, the easy part......2/3 gutted. So far, the only floor rot is by the door.
Name:	'63 Globetrotter 006.jpg
ID:	94945   Click image for larger version
Name:	'63 Globetrotter 007.jpg
Name:	'63 Globetrotter 008.jpg
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 01-29-2010, 03:39 PM   #30
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Looking good (well not really but you know what I mean)!!! Glad you took pics of those pipes. Forewarn you that most of that pipe is 1 1/4 ABS, impossible to find fittings and sticks of that pipe so do what you can to not cut it up if you're putting things back in place again. Also that smaller pipe coming out the kitchen wall for the vent is an odd sized pipe (I forget but its OD instead of ID or the other way around from normal pipe sizes). Been a PITA to deal with here. Am going to have to transition to 1/4 pvc most places but at least they are interior areas that don't flex much. Checked everywhere and nobody can even special order me sticks of 1 1/4, did find a few joints at the RV shop though.
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 03-10-2010, 09:56 AM   #31
Images: 30
Not much work on the Globetrotter the past couple of weeks. I own an automobile dealership that has a body shop and it's the guys in the body shop doing the majority of the work. They work on it in their spare time. My main job, so far, is giving the great advice from Airforums.
The front street side had damage that had some repair. The rib next to the window was also bent inward a couple of inches. When the panel came off, there was newspaper (from the year 2000) behind the panel used has a filler, because the rib was not repaired. The aluminum came in from Airparts yesterday.
Name:	'63 globetrotter dent.jpg
ID:	97851   Click image for larger version
Name:	Front streetside panel removed.jpg
Old 01-15-2011, 08:27 PM   #32
goransons's Avatar
1963 22' Safari
How's the project coming along?
Scott & Megan
VAC LIBRARIAN
WBCCI 8671
Old 01-16-2011, 06:04 PM   #33
Images: 30
I stopped last spring to get on another project. The '63 GT is 100% gutted and the shell is ready to come off.
I purchased a '75 Argosy 20' Motorhome. It's coming along just fine. I'll update that thread next week.
http://www.airforums.com/forums/f463...tml#post882690
I'll get back on the Globetrotter when the Argosy is finished.....
maybe 3-5 months??!!
Old 02-06-2013, 01:48 AM   #34
1963 19' Globetrotter
polacca , Arizona
Originally Posted by Overlander & Sea View Post
Scott,
Here's the pictures, hope they help. Just let me know if you need more pictures, such as, with the carpet removed.
To my surprise, the globetrotter came with several original documents on the refrigerator, water heater, stove/oven (which has been replaced), the fresh water tank, furnance, etc. I'll see if I can scan these documents and post them.
Did you ever publish those original documents you found on the fridge of your 1963 Globetrotter? I have the type of trailer, same model, same year, and I am looking for any kind of information on it, in order to restore it.
valeriaaz is offline   Reply With Quote
Old 05-28-2013, 05:18 AM   #35
hbeaumont's Avatar
Webster , Massachusetts
i have a 63 Globetrotter with all the original paperwork for everything. I can scan them and post if you like.
hbeaumont is offline   Reply With Quote
Old 05-28-2013, 11:23 PM   #36
polacca , Arizona
Scott,
Did you ever post those scanned documents somewhere? I also have a 1963 Globetrotter, I will be working on it over the summer and would really like to see some of this information.
Old 05-29-2013, 08:32 AM   #37
Images: 30
Here's a copy of a service manual that I already had. The refrigerator in my '63 Globetrotter is a Dometic MA35. I have not posted the documents that came with my Globetrotter. I'll try to scan & post them in the next week. My Globetrotter is still gutted, I stop the project in order to work on my '75 Agrosy 20' Motorhome. Good luck with your project!
Old 05-29-2013, 11:17 PM   #38
polacca , Arizona
Yes please, I would really like to see these documents.
Old 05-29-2013, 11:28 PM   #39
polacca , Arizona
Thanks for the manual, and I am interested in any other information you have on the Globetrotter 1963, when you get the chance. Good luck on your own project(s)
help with 63 globetrotter Wild Horse Member Introductions 4 02-03-2008 06:02 AM
'62 globetrotter wunderful62 1960 - 1964 Globetrotter 19 10-29-2006 03:01 PM
AC for 65 Globetrotter muddy_hollow Furnaces, Heaters, Fireplaces & Air Conditioning 23 06-17-2006 06:53 PM
64 globetrotter cpinkston Sinks, Showers & Toilets 2 06-14-2006 02:07 PM
'62 globetrotter Maya Axles 6 12-01-2005 07:45 PM
