Old 11-21-2009, 11:26 PM   #1
LoriK's Avatar
1963 19' Globetrotter
Crystal Lake , Illinois
Needing lots of help with the '63 Globetrotter
I am a total newbie to RV ownership and almost missed the fact that I need to winterize. It was only by reading this forum in the evenings, looking for restoration tips and help that I discovered the necessity of this important task. (thank you for being here!) The AS lived in Florida and before that it lived in Texas, so it has not needed winterizing for several years.
I would take it and have it done this time- but we have no tow vehicle yet. Luckily there is a Camping World not far from here, and I was able to pick up the items needed.
My first question: Which is the city water intake? I am assuming that it is the one that it is street side faucet at the front, but want to make sure, (I have no paperwork on this thing). Any help or suggestions will be greatly appreciated!
LoriK is offline   Reply With Quote
Old 11-22-2009, 05:21 AM   #2
65CV's Avatar
Western , Massachusetts
Manuals
LoriK-
Congrats on the new purchase. '63 is a great year.
We had a Globetrotter, but the plumbing had been changed. I don't recall a city water inlet. We used the external fill up front, closed the cap, and turned on the switch just to the right as you walk in the door. This pressurizes the system.
Most likely, you'll get a quick answer on these forums. You may find other manuals on this page helpful. The Vintage Airstream Club
Good luck with it!
John
65CV is offline   Reply With Quote
Old 11-22-2009, 05:26 AM   #3
toastie's Avatar
1955 22' Safari
Great Lake State , .
hope this helps
http://www.airforums.com/forums/f458...rize-7222.html
toastie
toastie is offline   Reply With Quote
Old 11-22-2009, 07:56 AM   #4
LoriK's Avatar
Thanks for the replies. I have already read all the threads that I can find on wiinterizing- which have been very helpful, but I am missing something. I think that the tank has been disconnected from the system. It is a beautiful day here and we have a little time, so I will try again to figure out why we can't blow the lines out.
Old 11-22-2009, 08:30 AM   #5
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
Lorik,
On our '63 GT, the city water intake is in the front & the fresh water tank is on the inside in the front. On ours, there is a faucet shut off in the inside by the water heater(street side), that drains the water from the tank & the water heater. The drain goes through the floor. Our '63 Globetrotter is Ohio built. Hope this helps, good luck.
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 11-22-2009, 09:22 AM   #6
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
If yours has the pressure water tank, there may be a faucet on the water filler neck up under the front window (and a drain under the trailer on the drivers side) that you use to fill. Depends on what is original, what has been upgraded, plus as many can attest to, there were many versions in 1963.
Post more pictures of your new project! Love to see it!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 11-22-2009, 01:53 PM   #7
LoriK's Avatar
That explains it.
Our tank is disconnected and there is no pump- and what we thought would blow through all of the pipes, only goes into the tank. The actual water "in" is what we thought was the drain (the one with the bucket)- in the middle of the street side bottom. I think that we have forced enough antifreeze into all to be safe for Chicago winter. Not sure if the water heater still empties out of the faucet at the front- that is very helpful information- Thank you!
attaching a few pictures of the plumming:
ID:	91386   Click image for larger version
ID:	91388   Click image for larger version
1965 Airstream GLOBETROTTER JLGT5107 Airstream Registry Discussions 0 08-19-2011 08:30 AM
Pricing '69 Globetrotter Modifications my3sonsdad Trailer Values 0 06-28-2011 11:49 AM
Who rents trucks to tow my 1962 Airstream Globetrotter? M Cordell Tow Vehicles 5 04-04-2011 10:36 AM
64 globetrotter front sofa bed Autumn 1960 - 1964 Globetrotter 26 02-11-2011 03:42 PM
