Old 06-01-2008, 06:19 PM   #1
GlobeTrottin's Avatar
1964 19' Globetrotter
Chelsea , Michigan
Mystery hardware - help 1964!
There are two horizontal channels attached on the curb side and one up high (under the rear window) on the street side of my 64 Globetrotter. I'm also curious if the hinge (see pic) is original. I know the rusting screws are not and I'm quite certain the "threaded hinge pin" is not OEM. Anybody know what the channels on the side might have been for? Maybe a table... who knows. I don't think I got any such attachments from the PO. Also, what steps to make the hinge more acceptable, look right, be right, not rust, etc.???
Thanks in advance.
ID:	61565   Click image for larger version
GlobeTrottin is offline   Reply With Quote
Old 06-01-2008, 06:39 PM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Wild Guess
If it helps any that's a bracket used for temporary shelves. The last pop up we had had one on it - the shelf had a matching bracket on the back that slid over the one you have. Under the shelf was a right angle triangle that folded down and rested against the side of the trailer body for support.
Old 06-01-2008, 06:54 PM   #3
cameront120's Avatar
1972 25' Tradewind
You could hang flower boxes from them!
North Vancouver, BC
Old 06-01-2008, 07:13 PM   #4
Moderator Emeritus
overlander64's Avatar
1964 26' Overlander
1978 Argosy Minuet 6.0 Metre
Anna , Illinois
Images: 183
Mystery hardware - help!
Greetings GlobeTrottin!
I can help with the main door hinge. It appears to be original. Some of the factory bucked rivets appear to have been replaced, and the original hinge pinge was not threaded. I have attached a photo of the door-within-a-door on my '64 Overlander that uses the same style hinge. The hinge pinge shouldn't be too difficult to source if the hinge halves haven't been sprung -- Ace Fogdall RV inserted new hinge pins in my Overlander's door several years ago.
Good luck with your '64!
Kevin
Kevin D. Allen
AIR #827
Old 06-01-2008, 08:17 PM   #5
NevadaGeo's Avatar
1978 31' Excella 500
Genoa , Nevada
My trailer has a clothes drying rack that fits on that type of a bracket.
NevadaGeo is offline   Reply With Quote
1964 Airstream Tradewind - Colorado D Bishop Airstream Classifieds 0 02-18-2014 01:27 PM
1964 Airstream Bambi II 17 - Virginia tlandeau Airstream Classifieds 0 02-08-2014 10:22 AM
