Old 08-20-2016, 08:04 AM   #29
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
Originally Posted by LYCAN92 View Post
Too little to late, I gave them to the county landfill, I thought they had no value, two of the six old ones where broken. Then later I find out from online at vintage trailer, that they were $500 a window. Oh well.
OMG!
moving way too fast dude.
twolanehwy is offline   Reply With Quote
Old 08-21-2016, 12:15 AM   #30
LYCAN92's Avatar
1963 19' Globetrotter
Chowchilla , California
Ya it is vary fast! only been working on it for two months.
Need it sealed up before winter!
Plus I want it to be like a small house "energy efficient" and from what I have seen on this Globetrotter, energy efficiency was not in mind, plus the underbelly they did not even seal up, insulated or water proof.
LYCAN92 is offline   Reply With Quote
Old 08-21-2016, 08:14 PM   #31
LYCAN92's Avatar
Name:	ImageUploadedByAirstream Forums1471831614.544052.jpg
ID:	269731Click image for larger version
Name:	ImageUploadedByAirstream Forums1471831634.446840.jpg
ID:	269732Click image for larger version
Name:	ImageUploadedByAirstream Forums1471831649.717112.jpg
Got rubber installed on the front underbelly and inside got Plasty dip spray and caulk over it all.
Will do this to the entire underbelly and the inside and then spray on polyurethane foam on it all, this kills many birds with one stone, insulates, sound proofs, water proofs, seals it, and keeps insects outside where they belong.
Old 08-26-2016, 11:14 PM   #32
LYCAN92's Avatar
Name:	ImageUploadedByAirstream Forums1472274769.580828.jpg
ID:	270096Click image for larger version
Name:	ImageUploadedByAirstream Forums1472274781.194666.jpg
Sprayed great stuff in and then put in insulation.
All ready for the floor board I cut out.
Old 08-27-2016, 10:23 PM   #33
LYCAN92's Avatar
Name:	ImageUploadedByAirstream Forums1472358169.775758.jpg
First section of floor is in.
Old 09-10-2016, 06:56 PM   #34
LYCAN92's Avatar
Name:	ImageUploadedByAirstream Forums1473555342.127140.jpg
Plan B ,
I decided to used aluminum trim instead of black rubber trim.
Old 09-11-2016, 07:35 PM   #35
LYCAN92's Avatar
Name:	ImageUploadedByAirstream Forums1473644094.533995.jpg
ID:	271526Click image for larger version
Name:	ImageUploadedByAirstream Forums1473644105.592651.jpg
Roof AC is now installed.
Old 10-07-2016, 11:15 PM   #36
LYCAN92's Avatar
Name:	ImageUploadedByAirstream Forums1475903006.866509.jpg
ID:	273081Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903026.616944.jpg
ID:	273082Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903041.668962.jpg
ID:	273083Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903061.377380.jpg
ID:	273084Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903074.644360.jpg
ID:	273085Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903089.428489.jpg
ID:	273086Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903129.759360.jpg
ID:	273087Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903140.841413.jpg
ID:	273088Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903167.445559.jpg
ID:	273089Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903176.991397.jpg
ID:	273090Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903188.312285.jpg
Lots of progress got the , all the rubber underbelly and rubber trim around the bottom, also got the Window trim done, Rain gutters installed, fresh water inlet, cable and phone, two new exterior outlets 110v, the whole interior Plasti dip sealed, got half the inside of underbelly waterproofed with Gluvit, and finally got the grey water tank, some drain plumbing and and two way drain valve installed.
Old 10-07-2016, 11:16 PM   #37
LYCAN92's Avatar
Name:	ImageUploadedByAirstream Forums1475903754.097703.jpg
ID:	273092Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903765.264296.jpg
ID:	273093Click image for larger version
Name:	ImageUploadedByAirstream Forums1475903780.235223.jpg
Old 11-06-2016, 08:34 PM   #38
LYCAN92's Avatar
Finished the subfloor sealed insulated and all the plumbing and ductwork done.
Name:	ImageUploadedByAirstream Forums1478489144.054541.jpg
ID:	274960Click image for larger version
Name:	ImageUploadedByAirstream Forums1478489184.008741.jpg
ID:	274961Click image for larger version
Name:	ImageUploadedByAirstream Forums1478489313.001212.jpg
ID:	274962Click image for larger version
Name:	ImageUploadedByAirstream Forums1478489342.052574.jpg
ID:	274963Click image for larger version
Name:	ImageUploadedByAirstream Forums1478489407.438671.jpg
ID:	274964Click image for larger version
Name:	ImageUploadedByAirstream Forums1478489446.808685.jpg
ID:	274965Click image for larger version
Name:	ImageUploadedByAirstream Forums1478489462.259484.jpg
ID:	274966Click image for larger version
Name:	ImageUploadedByAirstream Forums1478489571.621199.jpg
ID:	274967Click image for larger version
Name:	ImageUploadedByAirstream Forums1478489589.469620.jpg
ID:	274968Click image for larger version
Name:	ImageUploadedByAirstream Forums1478489603.818227.jpg
ID:	274969Click image for larger version
Name:	ImageUploadedByAirstream Forums1478489621.503936.jpg
Old 11-06-2016, 08:34 PM   #39
LYCAN92's Avatar
Name:	ImageUploadedByAirstream Forums1478489689.576962.jpg
Old 11-06-2016, 08:38 PM   #40
LYCAN92's Avatar
Name:	ImageUploadedByAirstream Forums1478489898.008672.jpg
Old 11-07-2016, 05:53 PM   #41
Central , Mississippi
Are you getting the plywood under the wall or butting it up to the old C channel? Kinda hard to see that detail in the photos.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-07-2016, 11:37 PM   #42
LYCAN92's Avatar
They all go under the walls, but I had to sand down the edges of all the plywood to get them to fit under the walls.
A New Challenge-1963 Overlander rehab project overlander63 1960 - 1964 Overlander 896 04-07-2017 04:48 PM
1963 Globe Trotter Winter Project Chrjbenn 1960 - 1964 Globetrotter 15 05-28-2013 05:23 AM
1963 Airstream 22 Foot Safari, The ultimate Project eBay Watch Airstreams on eBay 0 06-07-2009 03:37 AM
1963 Airstream 22 Foot Safari, The ultimate Project eBay Watch Airstreams on eBay 0 05-26-2009 12:40 PM
