09-05-2010, 07:51 PM
1956 22' Safari
2015 27' Flying Cloud
Conifer/Evergreen
Maxwell gets some TLC - 1964
Now that we are done with Birdy, our '56 Safari, it's time to get Maxwell back into shape! We originally did our restoration back in 2002 which at the time seemed like a MAJOR project. Several years and with Birdy's restoration behind us, we have some time to pay attention to a few "minor" projects we didn't need to address when we first got started. No floor-off resto is needed, just a few maintenance items. The toilet/black tank/valves and changing out the Univolt for an Intellipower are the first two projects.
The last couple of times we've gone out in Max, we've noticed something going on with the toilet & black tank. It seemed to have a slight leak and the original valve just wouldn't hold 100% - no biggie, we always tried to have full hook-ups - if we were boondocking, we'd take Birdy.
So, this weekend, we started to "dive in" to the situation to see what was going on. First we removed the toilet. This is "scary" because it is the original Swirl-O-Matic for which re-build parts are made out of "unobtainium". little did we know, it was practically just sitting on the tank un attached! The flange had rusted out and was just gross! But this made the Swirl-O-Matic (don't you just love that name!?) easy to remove. It was mounted on a piece of wood that spanned over the black tank. Kinda "hokie", but that's the way it was originally built.
09-05-2010, 08:02 PM
1960 24' Tradewind
St. Albans
, Vermont
Wow-impressive photos, but not in a good way! We are considering putting in a Nature's Head composting toilet in our Tradewind...perhaps you should do the same!
09-05-2010, 08:06 PM
1968 17' Caravel
Battle Ground
I'm jealous - I wish my toilet had a name as cool as a 'swirl-o-matic'!
Stephanie
1956 22' Safari
Conifer/Evergreen
Next, we cut the vent pipe and the grey water pipe. Then we had to remove what was left of the flange. There was no way it was going to unscrew - it was rusted too badly. So, Mr.InsideOut spent about 2 hours with a cut-off wheel cutting through the throat of the flange to separate it from the black tank. Finally we dropped the belly pan...double yuck! The black tank practically came down with it! It was basically resting on the belly pan...we knew we had some rust with the black tank pan (that's why we started this project ), but we had no idea how much! BEtween that and the crush/soiled 46 year old insulation - these pics are not for the feint of heart or stomach!
09-05-2010, 08:11 PM
1956 22' Safari
Conifer/Evergreen
Alas, it was free...
09-05-2010, 08:21 PM
1956 22' Safari
Conifer/Evergreen
We took the tank to the quarter-carwash and power wash it inside & out. It looked much better after that, but I didn't take any more pics. We discovered a couple of things...
1) The worst leak we had was from around the valve. It will be replaced as well as the old obsolete fittings. (Back in 2002, I searched high & low for a term cap to fit...now we won't be needing that any longer)
2) The black tank itself has two pinhole leaks, but nothing major. Mr.InsideOut used to glass surfboards and feels these two pinholes can be patched - no problem.
3) The toilet itself looks to be fine - dirty, but fine. We plan on just cleaning it up rather than cut into the fiberglass bench to fit a new toilet. This one is porcelain and should clean up fine.
4) We were able to remove the old valve without damaging the tank...so that saved several hundred dollars and we won't have to buy a new tank, which we were planning on doing!
I'll take & post more pics of our progress tomorrow...
Shari
09-05-2010, 08:22 PM
1968 17' Caravel
Battle Ground
Wow! I am stunned by how narrow that tank is! What's the capacity?
Stephanie
09-05-2010, 08:32 PM
1956 22' Safari
Conifer/Evergreen
I believe it's 10 gallons...but it is VERY shallow...no wonder it's easy to achieve a "cone effect" if your not careful! It is sloped to the center by the valve, so it flows well.
Our goal for this next week is to order up the valve, flange and metal box so those can be on their way. In the meantime, we will be working on the tank and general clean-up back there. If the parts don't come by next weekend, we will switch gears and work on installing the Intellipower.
That's it for now...
Shari
09-05-2010, 08:49 PM
Vintage Alum. Enthusiast
1959 24' Tradewind
Phoenix
I, too, am shocked by the thinness of that tank. Glad its all going to get fixed. Looks like Maxwell has hiding a secret for quite a long time.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
09-05-2010, 09:02 PM
1956 22' Safari
Conifer/Evergreen
We're so much wiser now...
The whole thing fits within the 4" frame...
Yep, if we only knew then what we know now, we would taken care of this project a lot sooner. We were pretty inexperienced in "restorations" first time around (and AirForums didn't exist when we started!)...it looked okay from the top side and we never looked further.
Shari
09-06-2010, 08:01 AM
1960 24' Tradewind
St. Albans
, Vermont
Wow-my 1960 Tradewind has a black tank that sits above the frame and not below-it looks like your black tank could potentially get clogged very easily.
09-06-2010, 08:23 AM
1956 22' Safari
Conifer/Evergreen
Yeah, our '56 sits above the floor too - different models have different tanks. Our above floor tank is a custom one we had made - it's taller and not as big side-to-side, it actually fits the curve in the "corner". Both are 10 gallons, just different configuration. We've not really had much trouble with the '64 tank clogging - but we "go light" with the TP and make sure it's always the RV type.
The '64 has that cool, sleek "airliner-design" bathroom, which is very cool and so easy to keep clean. It's a huge plus...who wants to spend all their time cleaning the bathroom when their camping? I makes up for the need to conserve on TP.
Shari
09-06-2010, 07:39 PM
1956 22' Safari
Conifer/Evergreen
Yeah, he was carrying around a couple other "secrets" too...
09-06-2010, 07:42 PM
1956 22' Safari
Conifer/Evergreen
Okay, so we are done with the demo phase and ready to move into the repairs. Valve parts are on order w/VTS, the new pan is measured up and the order will be placed tomorrow. So this week, we will fix the two tank pinholes and get the back ready for the new waste tank pan. Hopefully, we will get the pan back before the weekend and can get this wrapped up quickly. The Intellepower goes in next, but the waste tank has to go in first.
Here's a couple of pics of things cleaned up.
Shari
09-06-2010, 08:47 PM
1964 24' Tradewind
dousman
, Wisconsin
Hi Shari.
So glad that you are posting in regard to your waste system redo on Maxwell.
Thank - you for keeping us informed on your progress.
I have been just waiting for someone to do some work on one of these. My 64 TW has the same set up. Do you have the funky grey water double wye that comes in to the main waste pipe?? Have not been able to find the correct replacement part for that double wye...been putting my repair off to see what somebody else comes up with. Wish I could have saved my swirl-o-matic... the flapper was snapped off when I bought the TW.... and I was nieve and was thinking it would be easy to swap out. I found out different.
Karol
09-06-2010, 09:29 PM
1956 22' Safari
Conifer/Evergreen
Thanks Karol - glad you are getting something from this thread.
We have awe, the wye....we have a fitting that should work with the tank. Everything else will be replaced - new dump valve, and all the pvc to the grey lines can be adjusted to fit using the existing layout as a "go by". You can see the original grey line still attached to the wye thingy sitting on top of the tank in post #14. The new wye thingy is show in the photo in this post. It's not an exact replacement, but we can't see why it won't work...we got it from a friend (thanks Mark!) who did this project and used this part on his '64 Overlander a couple of years ago. The valve we are planning on using is from VTS.
Stay tuned...I'll let you know how it all lays out in the next week or so, as we are anxious to get this complete.
Shari
09-07-2010, 08:20 AM
1966 26' Overlander
Woodstock
, Georgia
thanks for posting all this. I believe a similar job will be in my future. The toilet in my 66 leaks, but not yet sure where, probably near the tank/dump line joint. The inlet water hose and one small one up front by the tank, are cracked so I can't yet run water in long enough to find the leak near the toilet.
Hope to do so soon.
09-07-2010, 08:54 AM
Patriotic
1973 23' Safari
North of Boston
, Massachusetts
Where did you get that wye thingy? (a.k.a. "collector") they don't seem to make them anymore...
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
09-07-2010, 09:31 AM
1956 22' Safari
Conifer/Evergreen
A friend gave it to us knowing that we had the same set-up he had. He found them at an old RV shop in Oklahoma several years ago and bought them up then brought them the the RMVAC Rally. We've had it at least 3 years waiting for the inevitable project. I did notice Inland RV has a similar collector fitting with a valve, but I haven't seen it in person - it looks like it may be made from more "normal" PVC parts (I could be wrong), but it is definitely bigger than the one we have. We have that as a back-up plan in case the one we have doesn't work. We'll see next weekend after the rest of our parts come in...
Shari
09-07-2010, 04:28 PM
1956 22' Safari
Conifer/Evergreen
So far, so good. We ordered up the new black tank pan - it should be ready by noon on Friday - just in time to continue with the project this weekend. Cool!
Shari
