Old 03-04-2011, 01:39 PM   #57
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Sorry Rob...that's a bummer! I wonder how that would have cracked...that's kinda odd.
I would certainly try to piece together some HD parts before you yank the whole thing & give up on it!!! Unfortunately, the alternative is not good (IMO) - the foot pedal lever "slot" won't work with any of the new toilets we found. So if you do replace it, you'll have to modify the fiberglass bench face (and possibly seat hight) to make it work. That's why we were so thrilled about being able to get ours to work...we spent a huge amount of time to do so, but are so pleased with how it came out - it was worth it, no regrets!
You may want to see if you can find another "dead" Swirl-O-Matic to scab parts from...that would have been our next step if what we did didn't work. Good luck!
Shari
Old 04-05-2011, 02:57 PM   #58
reddoor's Avatar
1965 22' Safari
LEONARD , Texas
Where did you order the new pan for the tank? We just got a 65 Safari with the under-floor tank like yours and are replacing it all. Actually, the PO took it all out and now we're trying to figure out what was there. We ordered tank and parts from Inland RV today, but I guess we'll need some kind of pan too. Thanks!
reddoor is offline   Reply With Quote
Old 04-05-2011, 06:23 PM   #59
InsideOut's Avatar
1956 22' Safari
Images: 108
We had a local HVAC shop make our pan out of galvanized metal to our dimensions. It helps to be in the business we are (arch/interiors/construction)...we know lots of those sort of folks...it does come in handy! But any HVAC shop should be able to help you out...
Shari
Old 04-09-2011, 03:14 PM   #60
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
Wow, its great to see how a project on a trailer like mind COULD be done.. you've answered a few questions. Did you redo the base of your swirlomatic? Mine was shot and I got a Nature's Head to replace it. The pictures and explanation on how to fix the tank and surrounding sheetmetal is a HUGE help. Thanks
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 04-09-2011, 08:18 PM   #61
InsideOut's Avatar
1956 22' Safari
Images: 108
Thanks!
We did clean it up and re-paint it - it was pretty cruddy cosmetically. We also rebuilt the valve and replaced the gaskets with new ones we made. They don't make replacement parts...but we were able to work with what we had. It now works better than ever since we've owned it.
Shari
Old 04-10-2011, 07:23 AM   #62
reddoor's Avatar
1965 22' Safari
LEONARD , Texas
I agree! We keep coming back to your pics too see what it's supposed to look like. Our toilet bench was cut out was by the PO and all the tank space stuffed with wood. We're slowly pulling it all out to get the underside back to the way it was at least. We'll just have to make the toilet look as good as we can.
Old 04-10-2011, 01:08 PM   #63
Globie64's Avatar
Images: 18
True confession: I cut the toilet surround to accept the Nature's Head. The fiberglass had cracked and was a little gross.. truth be told, it was fine, I just feel guilty for cutting it. I do want to replace the existing black tank to use as a gray tank, but that part of the trailer (behind the bellypan under the tank) is uncharted territory. Your pictures are like a map.
Old 05-08-2011, 03:16 PM   #64
InsideOut's Avatar
1956 22' Safari
Images: 108
It a beautiful day to show off Maxwell's freshly polished shine! Check out his newly updated website for more details ~
Shari
Old 05-08-2011, 03:58 PM   #65
Globie64's Avatar
Images: 18
Wow. Looking at the details on Maxwell, hot water heater etc, its great to see that you were able to get to old HW heater to work, I'm inspired to try mine- remove it, pressure test it, I imagine the controls can be replaced if necessary.
Old 05-08-2011, 04:49 PM   #66
star kitty's Avatar
1967 20' Globetrotter
denver , Colorado
Is there hope for mine to look that shiny after next week's maintenance rally? Sure hope so! Your trailer's are awesome!
star kitty is offline   Reply With Quote
Old 05-08-2011, 05:00 PM   #67
NicheVintage's Avatar
1965 26' Overlander
The Gorgeous Pac Northwest , Washington
Images: 34
Wow Maxwell is giving Birdy a run for her money with that shine!
WBCCI# 2578
Four Corners Unit
Our travel and resto blog:
http://web.me.com/tiffanydanley
NicheVintage is offline   Reply With Quote
Old 05-08-2011, 07:20 PM   #68
InsideOut's Avatar
1956 22' Safari
Images: 108
Yep, it's been running strong ever since we've had it - it probably worked before, but we didn't trust it until we fully tested it - as with all the propane appliances. No problems!
Shari
Old 05-08-2011, 07:28 PM   #69
InsideOut's Avatar
1956 22' Safari
Images: 108
Thanks Liz! Rob will give you all the "tools" and one-on-one he can - then it's up to you!
Yes, your trailer should be able to get that shiny too...we'll prove it with a small patch on Saturday - if you're still up for being this year's "demo-trailer". Oh yeah, you'll also need some elbow grease and Advil...oh, and a Jacuzzi doesn't hurt!
Shari
Old 05-08-2011, 07:32 PM   #70
InsideOut's Avatar
1956 22' Safari
Images: 108
There's nothing like a fresh polish job after a long winter...now it's Birdy's turn. But with outings planned for four of the next five weekends, I doubt she will get her touch-up before the Resto Rally ~
Shari
1964 Airstream Tradewind - Colorado D Bishop Airstream Classifieds 0 02-18-2014 01:27 PM
1964 Airstream Bambi II 17 - Virginia tlandeau Airstream Classifieds 0 02-08-2014 10:22 AM
