Old 09-08-2010, 09:07 AM   #29
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by campngirl View Post
Always have a plan 'B'.
...and 'C', 'D', etc....
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 09-20-2010, 12:19 AM   #30
InsideOut's Avatar
1956 22' Safari
Images: 108
So I thought we'd be farther along by now...but life happens! We had an unexpected visit today from Forum friends passing through town (and we're so glad they called!), so we didn't get to finish our project - but who cares, it'll be there next weekend!
Anyways, here's an update on our progress to date. We got the new pan, patched the pin-holes in our fiberglass tank (hey look mom, no leaks!), painted it, used foam insulation as a base and got the pan with tank installed. We also got the Intellipower installed and switched out some of the copper for pex/sharkbite fittings. All-in-all, it has been a pretty productive weekend AND we had fun visiting new friends!
Shari
ID:	111263   Click image for larger version
ID:	111265   Click image for larger version
ID:	111267   Click image for larger version
ID:	111269   Click image for larger version
ID:	111271   Click image for larger version
Old 09-20-2010, 12:20 AM   #31
InsideOut's Avatar
1956 22' Safari
Images: 108
More pics...
ID:	111273   Click image for larger version
Old 09-20-2010, 12:29 AM   #32
InsideOut's Avatar
1956 22' Safari
Images: 108
So far, so good - only a few cuss words were released and everything has worked out as planned! We think the hard part is done - the rest should be easy...hopefully we'll get this finished up this next week/weekend.
Shari
Old 10-18-2010, 05:59 PM   #33
InsideOut's Avatar
1956 22' Safari
Images: 108
Thumbs up Almost done!
Okay, so this project took much longer than we expected - why am I not surprised!?! BUT, we are thrilled with the results!
The biggest hurdle was ye ol' Swirl-O-Matic. Everybody says that once you touch it to fix something, it just falls apart and all the parts are made from "unobtainium, so just plan on buying a new toilet. The problem is, the way this toilet is built-in to the fiberglass "airliner" bench seat (see post #12), the bench would have to be heavily modified to work with a new toilet. As I understand it, new RV toilets are either 13" or 17" high - the Swirl-O-Matic is 15". So, you have to use a funky riser or jury-rig some other way to maintain the height. Then the location of the foot pedal means the vertical face of the bench also needs to be modified. I have never seen a retro-fit toilet that doesn't look like a retro-fit toilet in a '64 with this bathroom configuration.
I am proud to report this is NOT ALWAYS TRUE! With lots of patience, (approx. 40-60 hours over the last month, including umpteen trips to all the local hardware stores) careful disassembly, cleaning/painting and replacement of all the gaskets (some we had to make custom) and o-rings, we now have a Swirl-O-Matic that works perfectly! For the first time since we have owned this trailer, the bowl actually holds water and it's as good as new!
This last weekend, we got a new battery and put everything back in order and are so happy this is all behind us! I took this shot before we put the back trim, storage compartment and rubrail back on...but this'll give you an idea of how clean & fresh the back compartment is now. Quite a big difference from those at the beginning of this thread - dontcha think?
This weekend, I also stripped all the old paint off the bumper and POR-15'd it so it will be nice & smooth again too.
Shari
Old 10-18-2010, 06:14 PM   #34
InsideOut's Avatar
1956 22' Safari
Images: 108
Here are a couple of more pics...
ID:	113418   Click image for larger version
Old 10-18-2010, 09:08 PM   #35
safari62's Avatar
1962 22' Safari
1957 22' Custom
1963 16' Bambi
Vacationland , Maine
Images: 43
Originally Posted by InsideOut View Post
The biggest hurdle was ye ol' Swirl-O-Matic. we now have a Swirl-O-Matic that works perfectly! For the first time since we have owned this trailer, the bowl actually holds water and it's as good as new!
Shari
Swirl-O-matic's are supposed to hold the water in the bowl? I am constantly learning new things here on the forums!!!!!
safari62 is offline   Reply With Quote
Old 10-18-2010, 09:50 PM   #36
Paul Mayeux's Avatar
1954 22' Flying Cloud
1954 25' Cruiser
2005 25' International CCD
Paradise , Texas
Boy Shari, you and Rob are wizards! That looks fantastic.
Paul Mayeux
A&P Vintage Trailer Works, Inc.
AirForums #1565
WBCCI #7162
Heart of Texas Camping Unit
Paul Mayeux is offline   Reply With Quote
Old 10-20-2010, 09:48 AM   #37
InsideOut's Avatar
1956 22' Safari
Images: 108
Yeah, I know...who woulda thunk it!?!
Aw shucks Paul, thanks! Sometimes I'd love to just wave a magic wand and POOF! Projects are immediately completed - just the way I want them to be! We always try using some "magic words"...but they don't work!
Shari
Old 11-12-2010, 04:58 PM   #38
InsideOut's Avatar
1956 22' Safari
Images: 108
In the last couple of weeks, we have stripped & painted the bumper & tongue, replaced most of the belly pan and two corner end panels on the curb side. They both had small creases that just bugged us - so now they are good as new! This also gave us the opportunity to check the wood floor under the floor channel - it was as solid as could be! No floor rot at all! Guess we have one of those rare Airstreams that doesn't leak ~
We were also pleased to find no evidence of "creatures" in between the skins. The insulation was clean and fresh, even though it is 45+ years old!The next task is to finish up re-installing the front banana wrap, put the marker & tail lights back on, then polish the new panels to match the rest...
Shari
ID:	115070   Click image for larger version
ID:	115072   Click image for larger version
ID:	115074   Click image for larger version
Old 11-12-2010, 10:44 PM   #39
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
Well, there is not doubt that we'll never find moss growing under you two.
Barry & Donna
Life is short - so is the door on a '51 Flying Cloud (ouch)
safari57 is offline   Reply With Quote
Old 11-14-2010, 10:05 AM   #40
InsideOut's Avatar
1956 22' Safari
Images: 108
Maybe a little too close to home...but funny!
Shari
Old 11-14-2010, 10:28 AM   #41
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
you do amazing work, I guarantee the toilet was never detailed like that from the factory. wow!
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
wally:Restoring Wally Byam's 1955 26' European Caravan Trailer![/COLOR]
goransons is offline   Reply With Quote
Old 11-14-2010, 10:32 AM   #42
InsideOut's Avatar
1956 22' Safari
Images: 108
I'm sure you're right about that!
If it's worth doing, it's worth overdoing ~
Shari
1964 Airstream Tradewind - Colorado D Bishop Airstream Classifieds 0 02-18-2014 02:27 PM
