Old 05-25-2014, 06:36 PM   #1
1964 19' Globetrotter
Carmel , Indiana
Main Door Pins for 64 GT
Hi all, this is my first post on Air Forums. We are the proud owners of a very original and very well kept 64 Globe Trotter. This is our first AS and we LOVE it. I have noticed the bottom of the lower hinge pin is broken off. Something I learned from this forum that due to concerns of break ins by removing door the pins have holes drilled in the bottom of the and a retainer pin was used. Looks like it broke off there. this shorter then normal pin causes some binding of the bottom of the door hinge when the door is opened. Where can I find replacement pins for a 64? Looked at Inland and Vintage Trailer Supply but have not found anything for a 64.
AlumiDillow is offline   Reply With Quote
Old 07-08-2014, 03:53 PM   #2
Tim Eagle
tmeagle1's Avatar
1995 31' Land Yacht
Sandusky , Michigan
Send a message via MSN to tmeagle1
Not sure if you got an answer yet, I hope so, here's a link if you haven't found out where to purchase them yet: Airstream Door Hinges
Dark Nest Travels: youTube (content shortly getting there)
Dark Nest Travels : Blog (if you'd rather read our ramblings and history)
tmeagle1 is offline   Reply With Quote
Old 07-08-2014, 10:08 PM   #3
Carmel , Indiana
Ah Thanks but I just need pins not the hinges. I found these which work really well and with the screw in the bottom of the pin there is less chance of them falling / being pulled out.
Accurate MFD Products Z4890 Architect Bolt 8 32 | eBay
brake shoe retainer springs and pins.. safari25-05 Brakes & Brake Controllers 1 04-08-2007 05:17 PM
Source for ZipDee Snap Pins? Bob Thompson Awnings 7 03-19-2007 05:04 PM
Door Hinge Pins on 79 Excella Dano57 Doors & Locks 1 07-24-2006 07:35 PM
Cleco pins eubank Ribs, Skins & Rivets 8 02-23-2006 12:14 AM
toilet seat hinge pins? JohnGalt48 Sinks, Showers & Toilets 1 06-28-2004 11:05 AM
