Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Globetrotter > 1960 - 1964 Globetrotter
Old 07-15-2010, 03:02 PM   #41
adwriter73's Avatar
2005 16' International CCD
Looks great! Two questions...
1. What is that white tank in the kitchen cabinets? Is it a tankless heater?
2. Where did you get the new sliding doors for your upper cabinets?
adwriter73 is offline   Reply With Quote
Old 07-17-2010, 09:20 AM   #42
asbury park , New Jersey
1. it is a marey tankless LP HW heater. $150 - $200?
2. i made the doors! bought plexiglass at home depot, cut the down to size on a table saw, and used bits of masking tape to create the effect, and sprayed 'frosted' stuff on it to give it that look.
the frosted junk came in a spray paint can, also from HD.
NJtoNC is offline   Reply With Quote
Old 07-17-2010, 09:22 AM   #43
unless you have a plan to get the cold air up to the ceiling you may freeze your toes but you probably won’t be to comfy if you mount the AC near the floor in a trailer this size.
hmm... i guess i could put the ceiling fan on low , its an exhaust fan, wouldn't that draw the air up?
Old 07-18-2010, 04:11 PM   #44
adwriter73's Avatar
Very creative. I like. May have to steal this idea.
Old 08-16-2010, 09:34 AM   #45
alright, its nearly a month later and we have been making a ton of progress as we leave for our road trip in...18 days.
last weekend we made the cabinet doors (all except one) and did successfully execute the window a/c in the cabinet - its sitting in a drain pan. this weekend we got the floor in. lots of other little tidbits.
distribution panel - 110v working - still need to do the 12v cooktop & pumps..
blinds installed..
countertop in bath not installed, just dry fit
traded in old propane tanks, painted new ones...
AC in cabinet. door will be vented.
drip pan has a copper tube flared to create a flange, then a small hole driven through floor and pipe inserted. a flexible tube will be clamped on so it can be stored and not seen when not in use.
the drip pan, lined with aluminum, silicone overkill in corners...
also to follow up. this weekend we installed and tested the $150 Marey on-demand HW heater (LP w/ batt ignition). my concern was that it might not heat the water very hot - it was TOO HOT! and boy did it heat fast! immediate HOT HOT water. VERY happy with attempting this install despite having no predecessor (that i know of) trying this in an AS. only time will tell how long it lasts, but it does come with a 3yr warranty.
simple to install, must be vented (we used existing 4" - 5" furnace vent).
Old 08-16-2010, 10:04 AM   #46
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Terrific job...great idea on the ac in a box thing.
Amish Country Rally in Wooster Ohio, April 5-8, 2012 WineStream Other Rallies & Events 77 04-09-2012 06:22 PM
Ohio & Mississippi River Flooding Threaten Landmark Park overlander64 On The Road... 14 05-03-2011 09:59 AM
Recommended Ohio Campgrounds marvinr On The Road... 4 04-26-2011 10:11 AM
