Old 04-25-2012, 09:24 AM   #1
1964 19' Globetrotter
Uden , Noord brabant
How does stove work- 1964
Hi all,
Everything is original and working.
The last owner has also used the stove/ oven.
But we can not get it running.
Has anyone an user manual of the original stove?
Basicly the issue is that i don't know how to light / start the oven.
Thanks.
Martijn
The netherlands
GT64 is offline   Reply With Quote
Old 04-25-2012, 09:36 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
Hi Martijn,
If you look at the oven control knob, there should a spot that says "Pilot". Turn the knob to that spot, and push it in. Now gas will flow to the pilot light, which is located at the rear of the main burner. Light the pilot with a match. Not a very convenient place to put it, but I believe all RV ovens are built pretty much the same way. Once the pilot is lit, release the knob and the pilot should stay lit. Then you can adjust the oven knob to the temp you want.
Chris
Old 04-25-2012, 09:47 AM   #3
blmitch5's Avatar
2006 19' International CCD
Olathe , Kansas
This is a good how to video. I know it's for the newer units but should work the same way. Takes awhile to get it going.
Get involved and sign up for a Rally!
http://www.airforums.com/forums/calendar.php
WBCCI 4973
blmitch5 is offline   Reply With Quote
Old 04-25-2012, 10:23 AM   #4
Thanks a lot for your replies.
I think that i know what i did wrong.
I looked in the oven for the pilot to light it.
Probally when i look in the cabin below the oven i will find the pilot to light.
Principle is same as refrigerator. This is working fine.
Once i had trouble with lighting it, the issue was then that the trailer wasn't levelled streight.
Trailer is at storage, so i will try it soon and let you know if the apple pie was tastefull
1956 Overlander - needs work - $5500 faultytower Trailer Values 18 02-12-2014 09:36 AM
1964 Airstream Bambi II 17 - Virginia tlandeau Airstream Classifieds 0 02-08-2014 10:22 AM
