Old 06-05-2007, 04:16 PM   #43
2005 22' International CCD
Buckhorn , Ontario
Images: 59
Send a message via Skype™ to GT1963
Oh yes the ps thing - I know the original had the two tone paint job - but I am not into two tone reminds me of an Argosy (this comment is for Annies benefit - I am pulling her chain as we say)
Seriously I also do not like stripes either except in an awning......
Everything will be alright in the end. If it is not alright now, then it is not the end.
GT1963 is offline   Reply With Quote
Old 06-05-2007, 09:33 PM   #44
safari62's Avatar
1962 22' Safari
1957 22' Custom
Vacationland , Maine
Images: 43
Hello Again Sharon and Peter,
Looks like you are very busy with the remod of the new GT. That's a great size trailer and you will have the Overlander as backup when more space is needed. Since I have finished the restoration of my Safari I will offer a few suggestions if I thing they may/can help.
Sounds like you are worried about overspending your budget (already too late) on things like tools, espesially things like a rivet shaver. Shop around, but it is a tool that you will use much more then you may think. Even more so with multiple trailer disorder, which by the way you have.
Another tool I would suggest is an Orbital palm sander with an accessory vaccuum hose attached to a shop vac. I have a Porter-Cable orbital sander matched up with a Fien mini turbo vaccuum which is small and handy in small work areas. Great for reconditioning woodwork, fiberglass, walls,etc.
So keep up the updates as inquiring minds want to know! Remember Vince at the Rally trying to buy everyones trailers? Oh the memories!
Gary
safari62 is offline   Reply With Quote
Old 06-06-2007, 09:52 AM   #45
Mel
Mel's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Sharon, I have lights with a similar backing in my Caravel, and had to purchase a yard of the liner, so I have extra. If you like, PM me with your address and how many sheets you need, and I'll be happy to send them.
Mel
Mel is offline   Reply With Quote
Old 06-07-2007, 06:32 PM   #46
Buckhorn , Ontario
Images: 59
Just had to let all know - that this forum is a wonderful place and there are so many really nice people.
Mel has saved the day and I will be picking up the new linners at the Rivette Rally in a couple of weeks.
Big Thanks Mel!!!! If there is anything we can help you with, anything at all we will be most pleased.
Old 06-07-2007, 06:50 PM   #47
Buckhorn , Ontario
Images: 59
Okay a small window - with 1000 tasks lined up
Yesterday evening when it finally stopped raining I tried out the fancy picking tool - wow that worked great. While picking out the back window frame I clued into the trend.....
All the seams lead to the window frame - so the first two inches past each seam was dried out and rotten then it got a bit tough to pick out the vulkem just above the next seam and so on. The water is getting in deep behind the vulkem - it soaks and eventually at saturation it drips. That is why some see a leak and others do not. Short rains followed by hot windy weather will dry it up before anything substantial happens. Leave that combo for 44 years and you get rusted ground wires in the cross members to just about every connection in the trailer. Add in some serious leaking at the bumper compartment lid design and you get a rotten floor at the back.
Fixed almost.
Removed the old airstream emblems to find 44 years of dirt behind them - bad fit and no seallant.
I have new ones from VTS - did not want to worry about doing a great job on the old ones.
Worked on cleaning up all the seams and removing the duck tape up top on the vents - as they both were covering the seams. Then I called it an evening - getting real stiff these days - up and down a ladder and in and out of the trailer a 100 times....
Today was another productive day...nice and sunny this morning and cool so a good day to paint.
I took one look at the garage and thought how the heck am I going to do this - half the trailer walls are in here and the other half still in the trailer.
So it was a good hour re-arranging and making a big work table to lay the panels flat.
I was just about to paint and thunder and black clouds came in - I said to myself oh &^%$ not again. So I scambled to find the duck tape and dashed for the trailer. We had removed the J cross tire carrier and all the famous places for leaking I had just made even more leak ready - so I taped everything up. There went another 40 minutes and whole roll of ducktape.
Back to the garage to start the painting. It all went really well and I love the BIN paint for covering and fast drying power. It makes a really nice base.
I was able to finish what I started today but that did take me pretty much the whole day.
ID:	38782Click image for larger version
Old 06-07-2007, 06:59 PM   #48
Aria's Avatar
1967 20' Globetrotter
Sauquoit , New York
Sharon, What a wonderful job. You certainly KNOW how to. We have been busy trying to get Aria Rusello ready for a trip planned June 22nd. We put water in for the first time and we found a leak in the toilet.
We have it up and apart. The rubber gasket is rotted. Mel gave me Mark RV and we are going to call for parts in the morning. Some of the wood is rotted too. We are going to make a circle around (in the rotted wood area)
and use metal to give it strength.
Any suggestions? Are we going in the right direction? Aria
Aria is offline   Reply With Quote
Old 06-07-2007, 07:02 PM   #49
Buckhorn , Ontario
Images: 59
Now onto something way more serious....
Since I hope to bring Taz with me on the first Solo trip I thought it was a good time for her to come in and inspect the trailer.....and this is what she had to say...
Okay nice smell no old trailer smell good thing for you no good sniffs for me.
Now onto the inspection...you have not done the wheel wells yetClick image for larger version
and gee when do you plan on doing the belly pan?Click image for larger version
ID:	38787 I can tell you that there are no mice in here either - another good thing for both of us
Now there is a serious problem....you do not expect me to sleep on the floor do you?Click image for larger version
So tell me what you think folks - do you think she can get it ready - I'm thinking she is off her rocker but my Dad is right on with her and they really think they can pull off a rolling tin tent with a bed for me in 10 daysClick image for larger version
Kids ya gotta luv em - even the furry kind - if only they could talk...
Old 06-07-2007, 07:07 PM   #50
Buckhorn , Ontario
Images: 59
Thanks for the kudos....I will PM you on your questions.
Old 06-07-2007, 07:10 PM   #51
Buckhorn , Ontario
Images: 59
Earlier in our "Flight" I experienced my first booboo.
Well Peter enjoyed his flight this evening and saw the stars that are inflicted so many times to these tall people who do not watch where they are walking.....
OOOOOUUUUU
I will have to get some new noodles - as I gave all the yellow ones away with the 69 - the front and back windows of the 69 were sharp squares too - this 63 has an additional 4 windows for PETER to wack...
Old 06-07-2007, 08:15 PM   #52
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
Poor Peter
Sharon.. Are you pushing Peter into the windows again.. ??
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 06-07-2007, 09:13 PM   #53
safari57's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
West Coast , BC
Send a message via MSN to safari57
ANOTHER abused Airstream husband. It happens all the time. But being men we don't talk about it in the open. It looks like he didn't need stitches, which means no scar, which decreases the bragging rights points by half.
It's why I now wear a hat whenever I work on anything, or get near anything, that I can damage myself on. The right kind of hats even soak up the blood.
Barry
safari57 is offline   Reply With Quote
Old 06-07-2007, 09:14 PM   #54
safari62's Avatar
1962 22' Safari
1957 22' Custom
Images: 43
Ouch
Hi Peter
That's why Wally Byam wore Beret's. To hide the scar's. I need to get a padded beret myself.
STAY LOW MEN!
Gary
Old 06-08-2007, 07:45 AM   #55
We can tow it!
tin sista's Avatar
1996 28' Excella
Where the water tastes like wine , Michigan
Images: 82
Blood, sweat, and tears
Sharon, you might want to give Ladybug the middle name of blood, sweat, and tears!! Its going to be great when she's all done!!
Wow Peter bummer, looks like a hockey injury, Pronger Stanley Cup playoffs!
Steph in MI Air# 6996-
I Hockeytown USA!!
tin sista is offline   Reply With Quote
Old 06-10-2007, 08:49 PM   #56
Buckhorn , Ontario
Images: 59
Continuing along in Chapter 5 - The Metemorphosis
Right about now Peter is wishing that He could make metemorphosis happen and change into a LadyBug so he could fly away as far away from me as possible!!!!
Does anyone know how much square feet are in a 63 GT - NOT MUCH....
Must admidt - working during the week is very pieceful working together seems to strike a cord or two or three of four....
Peter has fully recovered from his head banging situation with the window and of course with the "task master" moi!. We settled with Peter working inside and I working outside - this was a much better situation as I was tired and grummpy most of the weekend. (I about had enough as I worked on it for several days before the weekend Not too mention that popping in and out of the trailer a 1000 times and up and down the ladder as many times - I have aggrivated my sports injury plagued Knee and it was really painful all weekend - which put a slow up on progress )
But - Peter was pumped - he had picked up the pieces for the skylight and was on the move Friday night and was &^%$ bent to get at least one big hole plugged up for good......oooooh honey......houston we have a problem.
I thought to myself - he cut one of the pieces wrong or scratched the skylight or something drastic....but not quite as drastic....For you fellows out there I will let you try and guess what the problem was.
With a project like this there is no room for dawdling - so there is always a PLAN B - so Peter moved onto to it..... You know you wannnnn it....AIR baby AIR!
ID:	38938Click image for larger version
Once this was mastered and working - heck why not move onto the Skylight anyway - still needs a nice sturdy framework and trim pieces for inside....
While Peter did all the really important stuff - I plugged on with "Leaks" Picking vulkum until I do not want to see anymore dried out vulkem as long as I live. Pick Pick Pick Pick Pick - but it sure does work great! my picking tool of course. Front and back window are done. All side compartments are done.
Then I moved to the battery compartment - as it needs a bit of help. I would like to put a heavy duty pull out drawer base in it - as there is no way I could manage putting in a heavy battery in that small space. I knew the wood base that sits on top of the floor was toast - water and acid damage. So out it came. Will continue to work on it later. The drip rail was picked clean and buffed up somewhat as the edges are way too sharp and I will have to do it by hand so I can avoid decapitating the compounding disc.
Kind of a boring picture really - after I looked at it. We do need a nice new green ground wire - this one is a bit cracked and corroded. Also need some knew spring catches - on order VTS.
We were starting to vie for the power cord - so I thought why do I not check out these sockets on the side of the trailer -I had read somewhere that they were for special lights - so I never bothered with them - besides I could not open them anyway.
Undid the two screws and the plate came off to reveil a standard single 110 plug - which hey matched the box inside the wall above the battery box. Both plugs got a full overhaul - and are now leak proof again and work like a charm.
Now to keep Peter motivated - I had to think about moving the LadyBug to a more suitable position on the driveway - one that is closer to the house, and to the patio and about the same distance from the garage. Haily thought it was a perfect place too - for now.... The dogs love to be in and out of the trailer and underneath it away from the "dearfly" that have come out right on cue!
ID:	38940 Poor little Haily was feeling a bit today- must have got into something she should not have yesterday. But she does like to be close to where ever we are working so that was a nice spot too where she can stay out of trouble.
Lastly for the weekend this expression sums it up - this is a don't &^%$ me off look - bad hair, bad clothes, bad nails, knee killing me, hot and the dear fly are driving me nuts...
Still a nice wife though - did you see the little yellow head protectors on the window!!!! Just so he would not poke his eye out and not be able to work on the LadyBug.
Lucky and Taz where having a pow wow too - and kept saying they will never make it - not in a Month of Sundays
1963 Overlander Complete Renovation Cardinal283 1960 - 1964 Overlander 175 04-26-2018 02:05 PM
1963 Airstream Safari 22 - Oregon Theburrs Airstream Classifieds 0 02-11-2014 09:51 PM
1963 Airstream Safari 22 - Arizona 1920jr Airstream Classifieds 0 01-30-2014 12:01 PM
Catarina 1963 Airstream Overlander :: 1963 Airstream Overlander utee94 Airstream Registry Discussions 0 08-19-2011 08:31 AM
