Old 01-14-2008, 09:04 AM   #1
1964 19' Globetrotter
Farnborough , Hampshire
Bathroom floor help - 1964!
Hi all,
I hope someone can help - we are in the throes of replacing the bathroom floor in our '64 GT and the old floor had a very large rectangle cut out of it, which makes it look as though the toilet was only resting on the black water tank, i.e. no wood support. I have searched the forum and the only photos I can find that are similar also look as if this rectangle cut-out is there. Does anyone know if this is right? I can't see any reason why it would not have wood there to support the toilet but I don't want to put wood there if I have missed something and it could cause problems in future!!
Grateful for any advice,
Dan & Lisa
RetroTrailer
RetroTrailer is offline   Reply With Quote
Old 01-14-2008, 09:13 AM   #2
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
Hi,
Welcome to The Forum. I can't answer your specific question but wanted to be sure you were aware of this site. A lot of good photos for reference.
64GT
Old 01-14-2008, 02:56 PM   #3
Thanks Gary! We have seen that site and you're right, it is very helpful, the Forums are priceless for info, especially as we're in the UK.
Cheers - Dan & Lisa
Old 01-14-2008, 04:34 PM   #4
2005 22' International CCD
Buckhorn , Ontario
Our 63 GT also had a large cut out of wood - and yes the black tank is supporting the toilet - but the tank is made of fiberglass. the area is still supported by cross members as well as some floor - not to mention that the tank is integral to the gelcoat top finish of the tank. This unit is then riveted to the back wall onto another support piece. So in essence there is plenty of support. The wood cut out matches the length of the "giant" brass pooper fittings they used back then - so if they needed any servicing you would not have to cut the floor after the fact.
I wish I had a pic of the hole in our floor for you - perhaps this one from my thread called flight of the ladybug http://www.airforums.com/forums/atta...8&d=1180277232
The square piece of wood sitting on top of the floor is about the size of the hole in the floor.....
If you are replacing with a poly tank then you will need a bit more support - as the poly tanks are not as strong as the fiberglass ones.
Good luck Dan and Lisa - if there is any other pics or info we might be able to help with by all means PM us -we have had this baby apart 3 times so we now where pretty much all the wires and plumbing are running too.
05ModPod is offline   Reply With Quote
Old 01-14-2008, 05:53 PM   #5
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Another informative option is to listen to version 61 of the Vintage Airstream Podcast (VAP) available through download from iTunes or go to 'thevap.com'. Each episode is an event and the latest episode covers most, if not all, of your bathroom floor replacement questions. Enjoy and tell 'em Brad sent cha.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 01-14-2008, 08:42 PM   #6
2toomany's Avatar
1973 23' Safari
1963 19' Globetrotter
Forest , Mississippi
hole under toilet
Lets see if this works here are a couple of shots from my 63gt that i am disassembling
2toomany is offline   Reply With Quote
Old 01-14-2008, 08:52 PM   #7
2toomany's Avatar
1973 23' Safari
Here are two more before the black tank was removed, Yes it is one piece and there are no wooden supports. Just riveted to the inside skin.
ID:	52534   Click image for larger version
1964 Airstream Tradewind - Colorado D Bishop Airstream Classifieds 0 02-18-2014 01:27 PM
What model has the largest bathroom? dale662 Airstream Lifestyle 4 10-09-2011 06:35 AM
