Old 04-29-2009, 10:22 AM   #1
flyrc's Avatar
1962 22' Flying Cloud
Yakima , Washington
'64 GT Restore or Part Out
I have a 64 Gt that was rolled into a mountain bank on the street side. I bought it for a great price and was ready to get started with the restoration as soon as the needed parts could be located. I found four used bows and the front and rear end caps. I haven't been able to find a complete side window or the window sash that I need to keep it original.
What should I do? Should I put in windows that are from a 66 or what ever I can find? Should I just sheet over the area and have one window? Or the last resort is to make the parts available to someone that needs them. I guess another option would be to polish it up and make it into a Taco Stand.
I was real excited about this when I found the Gt but can't see restoring it with other than stock windows or with a street side missing windows.
Any advise will be greatly appreciated.
Wally
flyrc is offline   Reply With Quote
Old 04-29-2009, 12:41 PM   #2
Overlander & Sea's Avatar
Gulfport , Mississippi
Images: 30
There may still be some windows on this Craig's list.
http://www.airforums.com/forums/show...&postcount=677
Rick--Airstream of Mississippi www.foleyrvcenter.com
WBCCI #9275 TAC #MS-5 AIR #11800
Overlander & Sea is offline   Reply With Quote
Old 04-29-2009, 01:33 PM   #3
VIKING's Avatar
Boulder Creek , California
There are some wreckers out there who specialize in travel trailers and rv's. I suggest trying to locate windows that way, or craigslist/ ebay.
It would be worth fixing it if you can come up with what you need. '64s are a special year. If you do part it out I would like to talk with you about it. I will be in need of some parts for my own '64 Safari, some of which are particular to that year.
Good luck, Rich
VIKING is offline   Reply With Quote
Old 04-30-2009, 06:42 AM   #4
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Windows through the 1965 year are flat single pane glass. 66-68 Airstreams used curved Corning tempered glass. The two are not interchangeable.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 04-30-2009, 08:32 PM   #5
VIKING's Avatar
Flyrc, I just found out this past weekend that the windows are also different from Ohio trailers to California trailers.
California has mitered corners on the outside window frame.
Ohio has butted corners.
The Ohio ones had window operators and latches that were different from California's also.
It may not matter so much which ones you use, as long as they look good and fit well. Airstream wasn't particular enough to standardize these in 1964 from one plant to the next.
Do you know where yours comes from?
Rich
Old 04-30-2009, 09:44 PM   #6
flyrc's Avatar
Yakima , Washington
64 gt
My Globetrotter was built in California. It has the kitchen on the curb side like most of the California trailers.Thanks for the info about the two different window frames. If someone has the butted corner type window could you take some high quality photos of both sides of the sash. Maybe I can have new sashes made.
Airstream trailers are interesting to say the least. It seems that what was in hand got installed in the trailer coming down the line. A friend has a 69 that has two different window types, some 69's and some 70's.
I have a lead on windows in Colorado. I hope I don't have to buy a trailer to get them. I don't want to have to decide which one lives and which one doesn't. I'll keep you posted.Remember, send photos
Thanks Wally
Old 05-01-2009, 03:38 AM   #7
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
These are pics of my CA built '64 Safari. I have a window that I need to work on, so one of the photos was about that. Also, don't get thrown by the reflection of a different Airstream next to it.
ID:	79477   Click image for larger version
Name:	IMGP2348 right angle.jpg
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 05-01-2009, 10:50 AM   #8
VIKING's Avatar
here's a couple of shots with window details.
How do you like the caulking?
Name:	'64 SAFARI 021.jpg
ID:	79485   Click image for larger version
Name:	'64 SAFARI 030.jpg
Old 05-01-2009, 12:12 PM   #9
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Silicon "stinks"!
TAC MN-6
WBCCI/VAC 11736
AIR 25979
Old 05-01-2009, 11:24 PM   #10
flyrc's Avatar
Yakima , Washington
Thanks for the photos. From what I see I need to pick up a tube of aluminum silicon. Since I already have duct tape, restoration work can begin.
Old 09-28-2009, 03:12 PM   #11
Globie64's Avatar
1964 19' Globetrotter
The Sea Ranch , California
Images: 18
silicon
I was told not to use silicon in contact with aluminum in a thread on this site... that it will corrode the aluminum.
Good luck with your Globie
Peter
Wherever you go, there you are
Globie64 is offline   Reply With Quote
Old 09-28-2009, 09:16 PM   #12
flyrc's Avatar
Yakima , Washington
It's being parted. There were just to many tasks that would require three guys to accomplish. I sent the main door and the access doors to VT. The parts saved a 64 GT from the scrap heap. I still have the bath and the end caps that I acquired while I was getting ready to start the repairs. It's been rewarding to know that the 64s parts are making other trailers complete.
I found a 56 Flying Cloud that has a great exterior , just needs floor and an interior :-) I'll post my progress reports as soon as I get started.
Old 09-29-2009, 04:55 AM   #13
1966 26' Overlander
1963 24' Tradewind
1990 34' Limited
Cape Coral , Florida
Flyrc, PM me if you want to sell the outside plumbing vent stack escutcheon from the 64 It'd be a big help.
dieseleagle is offline   Reply With Quote
Old 09-29-2009, 10:26 AM   #14
VIKING's Avatar
I'm renovating my '64 safari and would like to know what you have for sale. I would really like to get some of the cone lights from '64 if you have them, and a bowen water heater vent cover. My DW modified mine on the way to Burningman while trying to negotiate through a gas station.
I need other things that don't come to mind right now as well.
Rich the Viking
P.S. Would you entertain the idea of a trade for anything RC related? I have some antiques and some very cool planes and kits collecting dust.
Replacement part chrischarles Exterior Restoration Forum 2 01-24-2012 08:51 AM
Will this part help remove exterior rivets? bennyg Ribs, Skins & Rivets 6 11-17-2011 09:01 AM
2000 Excella window gasket A/S part # 381665 2000 Excella Windows & Screens 1 10-22-2011 06:30 AM
Part Numbers needed for Window and door gaskets Dog Doc Windows & Screens 2 04-24-2011 07:30 PM
