Old 03-08-2010, 04:39 AM   #99
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Interior panels in (well, 3 out of 4, anyway). I used the brake to dress the edge of the bottom panel on all 4 sides. I think it makes it look a lot more finished, particularly as I plan on leafing it polished aluminum.
ID:	97677   Click image for larger version
8576 • • • • • • • •
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 03-08-2010, 04:41 AM   #100
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
I am amazed at how much more rigid the door feels now that everything is sealed up and riveted together. 48 years of bumping down the road had loosened things up significantly.
Next up, the door within a door. I went ahead and made the skin for it to get a jump start. Then I took the little kiddies for a tractor ride. Too nice not too!
JP
ID:	97679   Click image for larger version
Old 03-22-2010, 05:29 AM   #101
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
I took my time with this one, and was so careful in copying the original, I actually copied some of the mistakes (slight misalignments, and angles)...
Then I tweaked it as best I could to get it as close to perfect as I could. Looks great!
First up, the obligatory "cleco pic", test-fitting the skin...
Old 03-22-2010, 05:32 AM   #102
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
On thing I've ALWAYS hated about Airstreams is how they use pop rivets on the door within a door. There's no reason you can't buck these, if you test fit things with clecos, then take it all apart, buck the inner hinge holes, and assemble it back together. The effect is well worth the effort. It IS the front door, after all.
ID:	98594   Click image for larger version
Old 03-22-2010, 05:36 AM   #103
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
Another thing i didn't like about the original door on the Globe Trotter was the complete lack of rivets across the top and bottom edges. Lack of rivets there allows the door to twist, and in my case, caused the door to catch and tear the skin (see previous posts).
Anyway, I wasn't about to build a flimsy door. :-) So when I made the interior panel, I made an additional brake at the top and bottom edges, so I could attach all 4 sides to the front skin.
While I was at it, I sealed everything really tight on the top and sides, but left a little gap at the bottom, in the unlikely event that water DOES get in the door, it will drain out.
ID:	98596   Click image for larger version
Old 03-22-2010, 05:38 AM   #104
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
finito! The door is 10X stronger than the original set-up. No twisting here! Ditto for the main door.
Old 03-22-2010, 06:54 AM   #105
That is some tight work, JP. Your aluminum skillz are superior.
Old 03-22-2010, 08:24 AM   #106
soldiermedic's Avatar
Florissant , USA
Mad Skilz indeed!
Streaming Soldiers Blog
soldiermedic is offline   Reply With Quote
Old 03-22-2010, 09:42 AM   #107
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
I wouldn't call them "skills"... I learn something new every time, and I'd probably never do it the same way twice!
Hobbies are all about experimentation, I guess.
JP
Old 03-22-2010, 10:29 AM   #108
pbearsailor's Avatar
Port Hadlock , Washington
Definitely makes a lot of sense to buck rivet those hinges on. That's going on my to do list.
-steve
Forum Thread: First She Had to Take a Ride on a Boat
Blog: My 57 Caravanner
pbearsailor is offline   Reply With Quote
Old 03-22-2010, 01:35 PM   #109
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
You see too many posts of these doors flying off NOT to!
JP
Old 03-22-2010, 07:49 PM   #110
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
Very very nice work! Glad to see how that comes apart, going to strip the interior zolatone on ours and rerivet since the door does have so much flex. Thanks for the great tutorial!
Scott & Megan
VAC LIBRARIAN
Restoring Wally Byam's 1955 26' European Caravan Trailer!
WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
goransons is offline   Reply With Quote
Old 03-29-2010, 12:50 PM   #111
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
You CAN'T beat a solid door on these old units. I think I'm going to rebuild the door on my '64 next. It seems only fair!
Speaking of the door, I found this on eBay, and riveted it to the inside top of the door. It came off a 50's Pullman coach. I think I'm going to leave the inside of the door satin so it pops like that. Very slick!
JP
Old 05-19-2010, 09:50 AM   #112
Birdie Momma
NJtoNC's Avatar
1957 26' Overlander
1956 22' Flying Cloud
Rutherford Co. , North Carolina
jp,
i read this post a while back when i had first purchased my 62 GT. almost 6 months later, i know the trailer inside and out, and re-read this thread. I can't believe how DIFFERENT it is from my ohio made GT. its like an an entirely different model! the windows are different, the storage bins, bath set up, etc. maybe some of that was mods from a PO on yours, i don't know.
at any rate, consider me your cheering section - and allow me to encourage you to GET BACK TO WORK on it! i want to see more pics
now on to read your other threads ...
'57 Overlander | '56 Flying Cloud | '51 Spartanette
NJtoNC is offline   Reply With Quote
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1960 - 1964 Globetrotter 12 03-27-2014 04:39 PM
Picture of my project 74Tradewind 1970-79 Tradewind 1 12-21-2002 09:14 AM
Serial number of 1960s Globe Trotter ? What year is it ? oldvws Our Community 1 12-12-2002 08:25 PM
