Old 03-06-2007, 04:07 PM   #57
muddy_hollow's Avatar
1965 20' Globetrotter
1956 22' Caravanner
Mendon , Massachusetts
Send a message via AIM to muddy_hollow Send a message via Yahoo to muddy_hollow
now the big question
how did you cut the aluminum into a perfect circle? Hmm?
56' Caravanner 'The Broomstick'
muddy_hollow is offline   Reply With Quote
Old 03-06-2007, 06:05 PM   #58
Addicted to Aluminum
A-Merry-Can's Avatar
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
well, i spose i should bestow my technique to you fellas, huh?
1) measure the hole, and add an inch to the widest part (including any extraneous holes you'll need to cover up)
2) with a fresh piece of aluminum, scribe a circle with a compass of the desired circle. i then coat it with a fast drying dye/paint and scribe it again so i can see the line clearly as a bright white line.
3) with a metal shear, i make a series of straight cuts just up to the line, but not touching it. you could probably do this with hand shears, too if you don't have access to a big shear.
4) on a benchtop belt sander, rotate the piece flat, and sand away the extra material right up to the white line. then flip it over, and just touch it with the sander to get the burrs off.
5) with light sand paper, dress the edges so they're nice and smooth
6) draw a straight line across the circle, right through the small center dot left by the compass.
7) with a protractor, mark off an angle, based on how many rivets you want to install. on my smaller patches, i wanted 6, so i drew the first line at 60 degrees (60 X 6 =360). on the larger patch i'm putting in tomorrow, i used 30 degrees (12 rivets). stay tuned for pics of that!
8) once all the tick marks are drawn around the edges, come in an even 1/4" on each one, and punch a small dimple. Now clean the piece with MEK, and revel in your work.
the patch i made tonight took 20 minutes, and should take another hour tomorrow to install on the trailer. i'll post pics when it's done!
remember kids, you heard it here first! good luck!
jp
there's always room for one more!
A-Merry-Can is offline   Reply With Quote
Old 03-08-2007, 04:47 PM   #59
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
last patch...
... i promise! now i need to order my light. i'm doing the recessed Grote light here. i think it'll look great! better than a hole, anyway!
jp
Old 03-08-2007, 05:13 PM   #60
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
thanks
Looks beautiful. Thanks for the step by step, I'm not there yet but I have a few holes I'd like to patch up eventually. Using a circle or oval pattern makes it look like it's not a patch, especially if you put something on there, like a bottle opener or some other useful gadget that attaches to the wall; a hook for towels, a metal sign of some kind, etc.
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 03-08-2007, 05:57 PM   #61
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
a bottle opener is a good idea! ha! think i'll stick with the light for this un, though. time to go ahead and orcer one, i spose!
jp
Old 03-08-2007, 08:36 PM   #62
1967 24' Tradewind
Images: 38
bottle opener
I can't take credit for that one! I saw someone on here had put a wall-mounted bottle opener in the middle of a patched area...one of those things I filed away to do eventually on mine. Even a connection for some kind of outdoor shower makes sense, somewhere, or a foot rinse for days on the beach...
Onward!
~ Hurley
ingrid
Old 03-09-2007, 04:51 PM   #63
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
i may have to finish stripping that side tomorrow, just for fun... IF the weather warms back up, that is!
the BIG Q now is... grab handle or not... i think i'm leaning not. it didn't originally have one, and if i put one in, it would fall between 2 ribs, so there wouldn't be much structure to it... unlike the handle on my other project, which falls right on a rib, and you can tell! it feels like i could lift the whole trailer with just the handle! ha!
can't wait to get this one caught up to the other, then, once both outter skins are done, i'll start on the 2 interiors at the same time.
jp
Old 03-18-2007, 04:29 PM   #64
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
More work on ol #51!
well, i have made a little more progress on ol #51 (aka "Stinky"). now that the patches are done, i decided to see how she'll shine up, starting with the curb side. since i'll be replacing the skins on both rear corners, i'm leaving that all nasty and original. i should be ready for the skin work in april (hopefully!)
i've also made the curb-side wheel trim from some left over material from the '59... oh, and most importantly, my porch lite is in! looks REALLY good, i think. MUCH better than a hole. i still don't get why this globe trotter has neither a porch lite NOR a grab handle. i'll probably be leaving the handle off as well, as she comes back together.
pics pics pics...
Old 03-19-2007, 06:05 PM   #65
Jacob D.'s Avatar
1964 26' Overlander
That light looks really great in the middle of that patch. I may have to go back and do the same to mine - mine was originally a 4-screw light that was a touch bigger then the 3-screw replacement I put in (original was badly corroded and had a broken lens), so I'm not entirely happy about how it looks. But I love the way it looks in the middle of a round patch.
Jacob D. is offline   Reply With Quote
Old 03-19-2007, 07:31 PM   #66
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
i thought about patching the holes from teh tail lights with round surrounds like those... bit i think moving them inboard is a better idea. plus, one of the rear quarter panels has a sizeable dent. best replace em while i can, i spose!
i almost with there was another thing to patch on this girl. i've gotten so good at the circular patches, it's a shame to stop now! haha!
jp
Old 03-19-2007, 07:32 PM   #67
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
now that i think about it... i may have to come up with a porthole for the door....
anyone know where to get one of those?
jp
Old 03-19-2007, 07:59 PM   #68
1967 24' Tradewind
Images: 38
cool
That's a great idea. I saw a bunch on eBay. Just type in "porthole".
You could get one that opens and when you have a visitor, yell "No one gets to see the Wizard, not nobody, not no-how!!"
Seriously though, I was pondering a window in our door someday and that's a super idea!
~ Hurley
ingrid
Old 04-01-2007, 01:29 PM   #69
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
i ended up putting the porthole on my other project. looks great, i think!
http://www.airforums.com/forum...ent-17197.html
jp
Old 04-01-2007, 01:33 PM   #70
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock , Georgia
more disassembly...
i just finished removing all the trim around the windows, in prep for paint (once everything else is done, i know...). while i was at it, i checked the wiring, and amazingly, NO shorts! everything works just as it should (and will!) amazing luck, on that.
i do need to run a 12v line up to the roof for the upcoming fantastic fan addition. for some reason, this trailer doesn't have 12v OR 120v run to the vent. maybe it wasn't standard to do so in '62, i dunno.
more soon!
jp
1963 Airstream Globe Trotter - Where Can I find these Parts Uncle_Phil 1960 - 1964 Globetrotter 12 03-27-2014 04:39 PM
Picture of my project 74Tradewind 1970-79 Tradewind 1 12-21-2002 09:14 AM
Serial number of 1960s Globe Trotter ? What year is it ? oldvws Our Community 1 12-12-2002 08:25 PM
