Old 03-12-2019, 05:51 PM   #15
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
No they weren’t. You may find 110 up there for a fan but it will not be a dedicated run and you’ll be begging for a fire. The good news is with some careful study you can usually hide most of a new runs in cabinets and fish wire. I did one I didn’t want to gut and used armor cable for the concealed area because I couldn’t install grommets. Since Airstream leaves gaps most of the time I was able to run it down parallel with a bow using a fiberglass electricians rod. Not ideal but as safe as you can make it without pulling skins.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
Wally Byam's 1955 26' European Caravan Trailer!
goransons is offline   Reply With Quote
Heat from A/C unit GaCamper LP Gas, Piping, Tanks & Regulators 4 01-15-2012 06:08 AM
2nd A/C for a 34' - 2002 Classic MarkM 2001 - 2005 Classic 10 11-17-2011 07:04 PM
A/C leak only with sideways rain Bowmans Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 10-07-2011 10:47 AM
1968 A/C not spinning fans on startup? hayduke Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-05-2011 09:21 PM
No Power To A/C (power at breaker) vhariable Electrical - Systems, Generators, Batteries & Solar 3 06-28-2011 05:54 PM
