Go Back   Airstream Forums > Airstream Knowledgebase > Airstream Trailer Forums > Bambi and Bambi II > 1964 Bambi II
Old 09-29-2016, 09:05 AM   #1
1964 17' Bambi II
San Antonio , Texas
Angry Need to remove original black water tank offset to line up with new toilet
I am replacing the original with a new toilet. It installs properly but
the flange hole to the original black tank is smaller than the new one which
leaves an offset in which paper and other things can hang up on. I would like
to cut this excess and make the hole larger. This material is uncuttable......
Im assuming its a black plastic but its acting more like cast iron. I was about
to resort to using a cutting torch but don't want to rush in if there is an easier solution. Used drills'/ recipricatng saw; grinders....
hammerbambi is offline   Reply With Quote
Old 10-03-2016, 12:38 PM   #2
Jewel65's Avatar
1965 17' Caravel
1965 17' Caravel
Memphis , Tennessee
Images: 21
The original flange was cast iron and probably impossible to remove without cracking the tank. Your original tank was probably fiberglass. I would be surprised if your original tank doesn't leak. I would replace the tank with a modern poly tank. That way your new flange will screw right in. VTS has the tanks.
1965 Airstream Caravel, 2003 Ford F150 SuperCrew, 2003 Miata Special Edition, 1993 Miata Black & Tan
Jewel65 is offline   Reply With Quote
Old 04-24-2017, 10:56 AM   #3
PA BAMBI II's Avatar
1964 17' Bambi II
1961 24' Tradewind
Strasburg , Pennsylvania
I am looking to install a new closet flange on which to install a new toilet...my tank is in good shape, but the mounting screws for the flange were rusted away and ground off before we had the tank re-gelled.
Can new holes be drilled/tapped into the cast iron tank fitting in order to install the modern plastic closet flange, or should I glue it in? I have access to a body shop at school and some pretty potent/strong adhesives.
Thanks in advance! Ben
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Black Tank, Grey Tank, New Tank, Old Tank Bunkroom Waste Systems, Tanks & Totes 3 07-22-2014 08:35 PM
How much toilet offset from black tank is OK? Sparky57 Sinks, Showers & Toilets 7 03-29-2012 01:22 PM
Need photos of toilet and black water tank. midcenminuet All Argosy Trailers 5 08-28-2009 08:27 PM
Need new black tank & toilet for 1963 Overlander Zstream Sinks, Showers & Toilets 2 07-01-2009 07:41 PM
Need to remove a 1966 GT Black Tank rideair Waste Systems, Tanks & Totes 5 11-15-2006 04:16 PM
