Old 04-04-2016, 05:35 PM   #1
Lights
Hi all,
Need some help.
History: Trailer not plugged in at all and interior lights were all working fine. I drove the Bambi to a bumpy sight where my wife had a photo shoot and now no interior lights are working.
Any recommendations on what I can look at or do to solve this problem.
Thanks in advance,
Huan Bui
Bui64Bambi is offline   Reply With Quote
Old 04-04-2016, 05:52 PM   #2
SteveSueMac's Avatar
2012 27' Flying Cloud
W , New England
Did you test your batteries? Did any of the bumps loosen a battery cable? Is your "use/store" switch in the "use" position? Did you check all fuses? If those 4 items check out, I'm out of suggestions. Sorry and good luck!
Old 04-04-2016, 06:05 PM   #3
Steve,
Thank you for your prompt reply.
When I opened up the compartment where the switches are housed, I saw the following:
A battery charger is plug in
The Lights is switched on the battery
To be honest I don't know the following:
Where is the Battery?
Were are the fuses?
Where is the "use/store" switch?
Forgot to mention that I have a 64 Bambi II
Old 04-04-2016, 07:07 PM   #4
W , New England
Well your Bambi II is a vintage I'm not familiar with but maybe these can help. First is a PDF of Airstream's brochure from 1964. The second is a link to the Bambi II threads here in the forums. Good luck!
https://www.airstream.com/wp-content...03ed50f15e.pdf
http://www.airforums.com/forums/f147/
Running Lights don't work, Other exterior lights work jrvly1976 Lights - Interior & Exterior 15 01-27-2015 09:27 PM
Tail lights, brake lights, turn signals on '75 22' mendosoft All Argosy Trailers 3 06-01-2008 08:46 PM
Running Lights/Backup Lights 85 Sovereign GRAYMAN Lights - Interior & Exterior 7 08-10-2004 08:54 AM
Upper Identification Lights aka(Clearance Lights) pap Lights - Interior & Exterior 7 04-08-2003 06:14 PM
looking for brake lights and back up lights larrylisa Lights - Interior & Exterior 6 12-07-2002 06:43 PM
