Old 07-27-2012, 08:45 PM   #43
(-1 Rivet_
REDSLED88's Avatar
1965 20' Globetrotter
Jackson , California
Cabinets
Originally Posted by beckybillrae View Post
Thanks, John & Ben for the pictures! That will help me a great deal when I get to the upper cabinets!! I may use a little of both methods when I make them. Thanks again!
Sorry Ben, not to shirk on your post, but Becky try talking with Peter (World in Chaos) who just re-did his '59 18 footer. I believe He used some tricks when attaching the cabinets to the interior skins/ribs.
I would think a couple of extra supports/angle pieces here and there wouldn't be such a bad thing.
Good Luck
TIMK
Thanks in advance!
TAC CA-77
REDSLED88 is offline   Reply With Quote
Old 07-27-2012, 09:42 PM   #44
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Good Luck
TIMK
I follow his thread, so I'll take a peek & see if he has any other ideas for me.
Thanks!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 08-17-2012, 07:43 PM   #45
PA BAMBI II's Avatar
1964 17' Bambi II
Strasburg , Pennsylvania
More progress...
I finally got some time to rip into the Bambi. It is almost ready for more subfloor removal. I have all of the lower interior skins off. I had forgotten how frustrating it is to have to clear the drill bit of rivet heads every five minutes! I also hate spinners (rivets that only spin when you drill 'em!)
I found some interesting things including some unused rivets buried in the wall cavities, a very nice Craftsman cold chisel under the refrigerator riser, one mouse carcass, many mouse droppings, a weed/vine growing up inside the rear window trim, and a lot of dirt. Also noted the lack of C-channel across the middle of the back wall like Becky and that the rear exterior wall is double-walled (exterior skin). I surmise that the factory workers changed their mind on a rear vent for the furnace which looks like it was originally supposed to be larger- then they changed it to a smaller intake and exhaust and added an access door.
The plastic refrigerator vent is probably too brittle and too far gone to reuse. I hope to have it fabricated in aluminum or steel.
I ended the morning of Airstream work by shop vaccing the interior out to make the work space a bit more pleasant. This was right before I went to shower to remove all of the fiberglass shards from my exposed arms! Next step is to remove another section of plywood subfloor and prep/repair the frame. Meanwhile I need to order insulation and marine grade plywood.
The pictures show a bunch of nails removed from under the threshold (I thought Wally did not use nails!), some broken skin to the rear/under the threshold, the infamous vine under the rear window trim, and interior wall removal progress. Can't wait to end the demo and start rebuilding! Enjoy!
ID:	166082   Click image for larger version
ID:	166084   Click image for larger version
"The difference between vintage and retro is that vintage is honestly old and cool. Retro tries to be but isn't."
PA BAMBI II is offline   Reply With Quote
Old 08-19-2012, 11:46 PM   #46
(-1 Rivet_
REDSLED88's Avatar
Awesome
Just pulled all my interior panels last week. Feels GOOD to get rid of that old insulation doesn't it?
I just need to pick up some POR15, and wood.
Where are you getting your ply from?
Size/Brand?
I think I'm going with 5/8" to save weight.
Looking good, keep it up!
TIMK
Thanks in advance!
TAC CA-77
Old 08-20-2012, 05:45 AM   #47
1964 17' Bambi II
Size/Brand?
TIMK
Thanks, TIMK. I hope to get out there this morning to remove the next piece of plywood. Then I am going to renovate the frame I have exposed and install new ply. Then I will work on the final two sections in the rear of the trailer.
It does not seem like a good idea to me to remove all of the original subflooring at one time so that some structure is left there. I am moving too slowly and would worry if the shell and frame were not tied together at all!
The local Lowe's quoted me for the marine grade plywood and have called me twice to see if I am ready for it- which I am not. I keep telling them I will be soon...regardless, I was happy that they can order it no problem. I will probably stick with 3/4" if that is the original thickness (need to measure it for sure). I do not know what brand.
Ben
Old 08-20-2012, 07:37 PM   #48
1964 17' Bambi II
Removing elevator bolts
I struggled a bit with how to remove the elevator bolts required to remove the first section of sub floor for frame repairs. I got them out, but it wasn't pretty. I took my cutoff wheel in the 4" angle grinder and cut the heads off through the plywood. This created a lot of smoke as the plywood got very hot.
This time I decided to go at it from a different angle. I got a medium sized hole saw and my drill. I drilled a hole around each elevator bolt head (with the pilot bit off center) about 1/4" deep. Then I chiseled out the circle of wood. This gave me greater access to the elevator bolt heads. I locked a vise grip on each one and wiggled it until it broke off, then tapped the remaining threads into the belly pan. We'll find those later. This procedure worked quite well.
For the screws and bolts around the perimeter c-channel, I still had to grind some of them off under the plywood. I almost have the second sheet of old sub floor ready to remove.
ID:	166312   Click image for larger version
Old 08-22-2012, 07:06 PM   #49
1964 17' Bambi II
Moving back...
When I got home from work today, I set the circular saw deck to 3/4" so that I could cut a slit in the second piece of sub-floor heading toward the back of the trailer. This is the section with the main door. After wrestling wit ha few unseen screws in the c channel, I got both pieces of plywood out.
The frame looks pretty good. There are a few iffy spots, but I am going to reinforce those spots and call it good. Cleaning and painting the exposed sub-frame are the next steps.
On a high note, I need to order some supplies! It is time to start building the old trailer back up now that she is almost completely stripped. I need to get the 7 wire harness to run through the frame below floor, insulation, and marine grade plywood.
I will try to post pics tomorrow of the exposed frame.
Old 08-22-2012, 08:05 PM   #50
Becky B.'s Avatar
1964 17' Bambi II
Making some progress, Ben! My words of advise are to NOT keep track of what you spend! (now that you're going shopping) It's pretty depressing!
Becky
1964 Bambi II
1988 Avion 32S
Old 08-23-2012, 06:28 AM   #51
1964 17' Bambi II
Frame pics
Well, here we are with the second section of plywood sub-floor removed. The frame looks pretty good all things considered. There is still original paint on some of it. I plan to repair some of the worst parts and run with it.
This is pretty excited! I am looking forward to starting to put some structure and elements back into this old trailer instead of just tearing them out!
ID:	166524   Click image for larger version
ID:	166526   Click image for larger version
Old 08-23-2012, 07:02 AM   #52
Becky B.'s Avatar
1964 17' Bambi II
Look for the missing stringers under the bathroom when you take it apart in the rear. Ours were cut out. They did that to make room for the shower & toilet drains. Not a whole lot of support was back there!
Becky
1964 Bambi II
1988 Avion 32S
Old 09-16-2012, 06:34 PM   #53
1964 17' Bambi II
AdvanTech vs narine grade plywood
I am having trouble finding 9/16" marine grade plywood and AdvanTech comes in 19/32" (close enough), but no one here carries that thickness. Every distributor carries 3/4".
An AdvanTech salesman is going to try to help me find some locally. Seems to me the dealers should be able to order 4 sheets of 19/32" for me and add it to a shipment of 3/4", but they will not do that. Seems like the potential customer holding the cash has no clout anymore. This is one sad reality as most companies and big box stores forget completely about customer service.
The only other blessing holding me up right now is the recent birth of our second daughter, Cora Ashley . I am totally stoked to fit bunk beds into the Airstream for my girls!!
Ben
Old 09-16-2012, 07:39 PM   #54
Becky B.'s Avatar
1964 17' Bambi II
We used the 3/4" Advantech, but since we did a shell-off, it didn't matter. Hope you can come up with something!
But more importantly, congratulations on your new baby girl!! My two girls are 6 years apart (we have 2 boys in between), but they are close now that they're grown. My sister & I are the best of friends & are close in age. It's great for girls to have sisters & doubly great for mom & dad to have daughters! They become more precious to me each day & yours will too!!! CONGRATULATIONS!!!
Becky
1964 Bambi II
1988 Avion 32S
Old 10-05-2012, 06:31 PM   #55
1964 17' Bambi II
Here's a photo for you!
The day before our baby Cora Ashley was born, the photographer liked the idea of using the Bambi for a photo opportunity! (Photo credit: Double H Photography, Lancaster, PA)
Old 10-08-2012, 10:52 AM   #56
(-1 Rivet_
REDSLED88's Avatar
5/8" Plywood?
Ben
What about using 5/8" marine ply?
Congrats on the baby!
TIMK
Thanks in advance!
TAC CA-77
Classic Motorhome Parts and Salvage streamquest Classic Motorhomes 111 09-21-2016 10:36 PM
02/12: New Tire Discussion on Woodalls: LT versus ST and more. slowmover Tires 128 04-10-2012 05:09 PM
Started the Clean and Wax routine today. Bruce B Clearcoat, Exterior Paint & Trim 12 03-20-2012 08:32 AM
Welding and using a cleaning agent first safari57 General Repair Forum 8 03-20-2012 01:00 AM
